Question about Aardvark Direct Pro Q10 (bundle) External Sound System
Problems with Aardvark Q10
When I run de Q10 driver any .exe freeze me up an doesn´t work. I have to reboot the machine. I use XP SP2. I have the last driver version for XP. SP3 can solve the problem? or any other sugestion? Thanks
  • jorgestark Mar 03, 2009
    Thanks for your answer. Great page for Aardvark user !! I use the 7.13 driver. I disabled all other sound sound cards from the system. The solution was to change the slot for the PCI card, it seems to work fine now. It´s an IRQ problem. Now I just have problem with Cubase 4, when I select more than 4 inputs - outputs, the program close. Cubase 3.1 the same. Other programs work fine like Live. I would try with Sonar. Any other suggestion? Thanks again.
  • 4 Answers
You can use it with sp2. just make sure you have disabled any other sound cards on your computer in the hardware device manager. you can download the drivers and manual here...make sure you use the 7.13 version
http://www.michaelchagnon.com/aardvark/download.html
Posted on Mar 02, 2009
    New Friend:
Run new Windows 8 Wizard and check your Hardware and Software solution.about upgrate on Windows 8. When I run the wizard, I see my Q10 and You mybe will see there your Aardwark audio hardware: Aark 24, Aark 20/20 and Direct Pro Q10 too. Are this hardware work correct on Windows 8, I don't no? Someone must to try and check this new W8.
Posted on Jan 12, 2013
  • 4 Answers
After reading these forums, I have a good idea of what I need to do to run my Aardvark Q-10 & Aardvark 24/96 on Windows XP SP3 on my Intel Q9550 quad proc & Gigabyte GA-P43-ES3G v1.1 mobo.
. I'm going to summarize those ideas below & cite sources, but first I'd like to submit my theory explaining why Aardvarks work so badly starting with XP's Service Pack 2.
XP's SP2 & Win2000's SP4 introduced a 36-bit addressing system called PAE, which was designed to support more than 4GB of RAM (never quite worked right), as well as the use of Data Execution Prevention (DEP). SP2 installs the capability & automatically turns it on, just to screw with us. This was done after the Aardvark drivers were written, & even ProTools had problems with PAE; lots of stuff did.
Fortunately, PAE can be turned off. This is what worked for me, in my c:\boot.ini file:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /fastdetect
To check to see whether it is really off (after rebooting), open the System Control Panel, and check on the General tab. If it says "Physical Address Extensions" anywhere under the Computer heading (usually on the 4th line, under the line that says how much RAM you have), PAE is enabled.
If it's still running PAE, try one of these in the boot.ini file instead.
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /NoExecute=AlwaysOff /NOPAE /KERNEL=ntkrnl.exe /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="WinXP Pro Corp SP3" /execute /fastdetect
(it's different in Vista so if you're crazy enough to try using the Aardvark in Vista, read this: http://thehunk.blogspot.com/2007/06/disabling-physical-address-extension.html)
sources
http://duc.digidesign.com/showthread.php?t=130383
http://www.msfn.org/board/topic/80046-help-do-not-enable-pae/
http://forums.overclockers.com.au/showthread.php?t=398765
http://msdn.microsoft.com/en-us/library/ff557134%28VS.85%29.aspx
general approach to using an Aardvark in Windows XP SP3 on a multi-core computer
1) It helps to know the *rest* of your hardware works right. With the Aardvark cards not installed in the computer, run Memtest86+ for 24 hours with no errors.
2) Install Windows XP. (Do not install any drivers, even motherboard chipset drivers or graphics card drivers. Also, keep it off the network since it's unpatched & unprotected.)
3) Disable PAE & DEP by modifying boot.ini.
4) Disable the computer's internal sound card in the BIOS if you can, and/or in Device Manager.
5) Run the Prime95 blend stress-test for 24 hours each with no errors. If you get errors in these tests you have to fix that issue first.
6) Use Acronis or Ghost to create an image of the partition exactly as it is now, before installing any drivers or system updates. This way, when it crashes, you can reset to this safe point quickly.
7) Physically install the Aardvark cards into the machine.
8) The order in which you load drivers matters. If your first attempt doesn't work, try doing things just slightly differently the next time. Write everything down to keep track of what you try and what happens. First attempt, try loading the motherboard chipset drivers first, then the display adapter, network card, etc & finally the Aardvark drivers, version 7.13.
9) Aardvark drivers 7.13 and 7.14 support hyperthreading and multi-core processors; 7.04 does not, but some people have success with 7.04 so don't assume anything. (7.04 crashes my new computer hard, but seemed to work better on my Athlon 3000+)
10) You may have to try switching which PCI slot the card is plugged into, or try to assign the IRQ in the BIOS or in Windows Device Manager.
11) If it absolutely won't run in your system using XP SP3, try XP SP1 (clean install, not a roll-back). Keep your machine off teh internets for gods sake (or you'll get wormed in 30 seconds & your computer will be a spambot).
12) Set the "timing master" in Sonar or similar programs to your last set of inputs. If you have an Aardvark Q10 in your system, this would be 9/10. (In my case, I think it will be my second card's last outputs, so it's my 24/96's 5/6 inputs.) Also, disable any read & write caching.
sources
http://www.fixya.com/support/t1516728-aardvark_q10_no_drivers_cd
http://www.fixya.com/support/t4047907-installed_xp_hot_fix
http://www.fixya.com/support/t1716701-problems_aardvark_q10
http://www.fixya.com/support/t3260184-aark24_installed_computer_windows
http://www.michaelchagnon.com/aardvark/software_sonar.html
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=25505&Keyword=Aardvark&Archive=showarchive
http://www.sweetwater.com/sweetcare/ts/detail.php?Index=28034&Keyword=Aardvark&Archive=showarchive
Posted on Jul 24, 2010
Installed xp hot fix, then aardvark would not work, so I uninstalled hot fix. Now when I install cd for software, I get aarkthk.dll not found. Please help
All aardvark interfaces will only work well with xp sp1 or earlier 2000/win98. Also, dont simply uninstall SP2, 3. You have to unistall/reinstall xp, xpsp1 and then if needed, go to the microsoft download pages and get all the updates prior to SP2. Pay attention and make sure you dont install SP2. Do all of this with the pci card pulled and all aardvark drivers uninstalled/deleted. Then install per aardvark's instructions. I dont recommend internet usage without SP2. You will be vulnerable to attacks even with the best protection.
Feb 04, 2010 | Aardvark Direct Pro Q10 (bundle) External...
I have a aark24 installed on my computer windows xp operating system and cubase sx3 The Aark 24 is not working My latest driver update is 7.13. is there maybe a update driver software available?
Aardvark is only stable with xp sp1. 7.13 and 7.14 are the last drivers ever made. They were made prior to SP2
You will have to pull the pci card, delete all the aardvark drivers and reinstall windows. Then go to windows update and install everything up to SP2. The stop and turn off auto updates. Dont surf after that. Unplug any internet connections.
Oct 23, 2009 | Aardvark Direct Pro Q10 (bundle) External...
I need the LX6 Direct Pro Driver for windows vista. All of the drivers i have tried say there do not support that OS. Do you have this driver or know where i can get it. Also do you know if the...
Aardvark had went out of buisness about 3 to 4 years ago. Unfortunately they didn't last long enough to write a driver for vista. Sorry to be the bearer of bad news. I love aardvark I had the LX6 and still have the 24/24 and Q10. Too bad they only work up to XP. Sorry. driverguide.com still has the XP driver.
Oct 01, 2009 | Aardvark Direct Pro LX6 Sound Card
Aardvark Q10 with no drivers/cd
you can use it with sp2. just make sure you have disabled any other sound cards on your computer in the hardware device manager. you can download the drivers here...make sure you use the 7.13 version
Jan 10, 2009 | Aardvark Direct Pro Q10 (bundle) External...
Will my Aardvark Q10 work with a new machine with Vista?
I have heard that the drivers will not work in Vista. But, you can get the XP downgrade (sometimes for free) and still be able to use your Aardvark on the new machine. As for the PCI slots being different, I wouldn't think there would be an issue. If newer machines had PCI slots with lower voltage or other differences, this might make them incompatible with a whole slew of older PCI cards. As far as I know, the only issue is with the drivers.
Dec 30, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark q10
you can set the driver signing warning to 3 levels, ignore - warn - block. Yours are set to block. If the driver is not "official" according to microsoft's lists, the OS will not allow it to be installed. I know this because Roland doesn't get their drivers signed, and give specific instructions on how to change the setting.
control panel/system/harware tab/driver signing. Make your setting.
Jan 27, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Drivers for windows vista???
this manufacturer no longer exists and only XP drivers can be found, no Vista i'm afraid
Aug 24, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Problem
You are looking for: "6' length, custom 25 pin shielded cable" Try on shopping.com or Amazon...: http://www.shopping.com/xFS?KW=custom+25+pin+shielded+cable&FD=0 You will find it there.. Good Luck. K.
Sep 10, 2005 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark Direct Pro Q10 (bundle) External Sound System Logo
722 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
