Question about Crafts & Hobbies
DualMelt stanley glue gun
Hi, Wonder can anybody tell me if it's best to use the low heat setting for sticking fabric to wood to get a neat and hidden seam edge on upholstery ? or maybe It's not meant to be used for this purpose ?
Thanking you in anticipation.
Tina
    Sniper:
  • 86 Answers
For polyesters, rayons, nylon - yes use the low heat setting. The high setting is so hot it can actually melt some synthetic materials. The difference in adhesion between the two settings is minimal. Use the low temperature glues sticks if the gun says there is a difference.
You can use it for this purpose, but it may not be a permanent solution depending on how much stress or load the fabric is seeing (being stretched) when using the furniture.
The best upholstery edges are usually stapled - where the edge or hem of the material is left longer than the area being covered. A picture would be helpful if you want to know the right way to make the edge.
Posted on Mar 02, 2009
  • Gregg Rene Mar 02, 2009
    Not liking the answer is not the same as not getting the answer. Tina, how did my solution not answer your question? You asked if its best to use the low setting and I answered Yes, it is better to use the low setting. You asked if its not made for this purposes, and I answered no it's not the best solution, the best solution is to follow normal upholstery processes if you want a lasting solution. I even offered to look at the problem if you uploaded a picture. Why did you respond Thanks For Trying as an appropriate response?
Is there a seal between the nozzle and the tip? I have glue leaking out everywhere??
No, no seal. The heating element is just a heated tube with the nozzle simply threaded into its end. The heating element in your glue gun may be cracked. Or... possibly... you (or someone in your household) got it hot and laid it down and left it that way for a LONG time, and the melted glue backed up inside the heating element. A glue gun should never be laid on its side while hot but idle, especially for long periods of time.
Jul 31, 2014 | Stanley GR100 DualMelt Pro Glue Gun Kit
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
What type of glue is used for glue guns?
There are different types of glue sticks and these are selected depending on the material being glued. Some glue sticks are more suitable for wood based materials whilst others are for general gluing of a variety of materials.
Jan 10, 2013 | Crafts & Hobbies
Wires detached stanley hot glue gun
Not sure about the wires, but you can contact Stanley customer support here:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
also, check and see if the gun is still under warranty, you may be able to exchange it for a new one
Dec 24, 2012 | Stanley Bostich Heavy Duty Dual Melt Glue...
Stanley heavy duty dual melt glue gun not working
can you elaborate on this problem at all? is the glue not heating up? is it not getting power? what is happening?
Nov 13, 2012 | Stanley Bostich Heavy Duty Dual Melt Glue...
Hi, can't get Stanley dual melt glue gun to
some users have complained that the trigger fails. when this happens, the glue will not heat up. if it seems to be a problem with the trigger and the gun is relatively new, i would try to return it and get a new one or get your money back
Nov 13, 2012 | Crafts & Hobbies
I have a glue gun (brand = POWER CRAFT a german product stated) I forced the glue stick into the gun to use up what was left of it and now I cant get it out. Its completly stuck inside the gun. Is the...
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Dec 07, 2010 | Crafts & Hobbies
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Crafts & Hobbies Logo
210 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
