Question about Singer 3116 Simple
Does not make a stich
The thread does not pick-up the bobbin thread when trying to make a stitch will go a few stiches and make a glob of thread and clog the pressure foot
this is a new machine and has stiched the last two times I used it this is only the third time I have used it and did not change anything before I tried to use it again
  • 26 Answers
You may find that the needle is bent. or maybe the machine needs a cleaning I use canned air for this it blows the lint out so nicely . if this is a new machine then take it back to where you bought it and see what they can do.
Posted on Mar 08, 2009
Skip stiches
Changing the needle may be helpful. A bent/damaged needle will tend to not pick up the bobbin thread properly.
Try a different type of thread--avoid old or bargain bin threads.
Could also be an incompatibility of the needle, thread, and fabric.
All About Needles
If it still skips stitches, then it may have a needle/hook timing issue that would require service.
Aug 19, 2016 | Sewing Machines
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
Trouble shooting
its the tensioner knob turn it a little bit till the stitch is back to the way its suppose\ed to be, don't turn the knob a lot ust a hair a little AT a time try the stitch each time you turn it to see if the stich is tight again. The knob has numbers on it you have to d this in straight stich setting
Apr 28, 2017 | Sew D'Lite Lightweight Portable Mechanical...
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
My singer sewing machine model # 774 will not produce a lower stich that is not all jumbled on the underside of the fabric. The upper stich is fine, it's the bobbin stich that comes out all jumbled. ...
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 08, 2011 | Sewing Machines
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
I have the same problem
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 27, 2009 | Kenmore 15208 Mechanical Sewing Machine
I HAVE Kenmore 385 165 24 bobbin case is loose and I can not get even one stich. Do I miss a srew to hold it in a place? Thanks for help.
if the bobbin case is loose and pops out when started. it is not inserted correctly
make sure you hold the clasp when inserting case and hear the slick into place
make sure upper thread is threaded right and the bobbin thread is even
bring bobbin thread up and pull both threads to the back about fou inches
hold threads and stich a few stiches by hand or foot pedal befor letting fo of the thread.
Aug 26, 2009 | Kenmore Sewing Machines
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 3116 Simple Logo
102 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
