Question about Sharp XL-DK225 Shelf System
Lights flash on the unit at night making it hard to sleep!
My son has a Sharp XL-DK255 system and it has all of these cool lights on the front panel that flash and blink. The problem is at night its kind of a distraction. Is there any way to disable the unit from flashing other than turning the unit off?Thanks!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
Posted on Aug 14, 2009
Hold the power button in for a few seconds. It seemed to help.
Posted on Mar 15, 2009
Tip
Make Your Keyboard Lights Do DISCO
Friends this is just a small trick that will just make your dance means its lights will go like disco lights of a midnight club.your keyboards light goes in rhythmic way it too cool u try and make fun .These codes when executed makes your Caps, Num, Scroll lock keys flash..
very cool...i hav tried it...
1.This piece of code makes ur keyboard a live disco...
Set wshShell =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 100
wshshell.sendkeys "{CAPSLOCK}"
wshshell.sendkeys "{NUMLOCK}"
wshshell.sendkeys "{SCROLLLOCK}"
loop
2.This one makes it looks like a chain of light....
do
wscript.sleep 200
wscript.sleep 100
wscript.sleep 50
loop
Instrcuctions:
*paste any of the two above codes in notepad
*Save as "AnyFileName".vbs
*Run the file
*to stop, launch task manager and then under "Processes" end wscript.exe
I hope u would like it...
on Dec 23, 2009 | Computers & Internet
Sharp XL-DK255 timer light is flashing but stereo doesnt work
The problem is the audio output ic has failed in the unit, the ic must be replaced to fix the issue.
Mar 10, 2012 | Sharp Audio Players & Recorders
My son was playing the wii and his remote hit the TV. Now the tv will not power on and the power light and opc lights are flashing? Anything I can do?
You probably damaged the panel. If it's under warranty contact Sharp and request service. sharp does not replace panel under warranty . they usually replace the tv. It's worth a try.
Aug 31, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I want to connect my XL-DK255 to my TV (Sanyo DP26671). Please help!!!!
http://www.manualowl.com/m/Sanyo/DP26671/Manual/211922
the only way to connect them is audio ...and you can either connect the Tv to the system ..(for better sound ) ..and in this case use the rca (left /right ) to rca (left right ) on the sharp ..if it supports..or ..use a double rca stereo cable ..with a jack 3.5 end ..and insert it in the audio input of teh sharp system ..
The signal from the Tv it will have to be taken from the audio out like in th epage 13 of the manual ..(it has a mono exit ..on rca probably ) and a left and right stereo one ..
If the sharp supports rca stereo in ...use it ..or ...just use the jack (3,5 stereo ) in ...and do not forget to select the proper channel ..
if the sharp system has a TV input channel for sound..on the receiver..use it ..and select the TV to playback the sound ..if it do not ..use the aux.. and selct the aux for control it ..
I do not believe you need to connect it in the other way cause it is not make any sense ..but the procedure is the same ..get audio signal from the system and insert into the audio in of the TV ..it is in the same place and also available mono and stereo ..You will have to select the input in the tv menu..
The cable you need for a stereo connection I think will look like thi s..
http://www.alibaba.com/product-gs/369945799/Factory_direct_supply_Adapter_Cable_jack.html
Jul 20, 2011 | Sharp XL-DK225 Shelf System
Hi! I'm a music teacher who just came back from summer vacation and plugged in my xl-mp130. It seems to be in sleep mode or something. There is a little red light that blinks just below the word...
i would do a hard reset to start and that is simply unplugging the unit for approx 5 mins than plugging it back in--a power surge or brownout can confuse the micro and a reset is all it needs sometimes--good luck!
Sep 01, 2010 | Sharp XL-MP130 170-Watt 5-Disc CD Micro...
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Blinking lights
i have same problem, do anyone know how to fix it? thx
Jan 10, 2008 | Sharp LC-32P50E 32 in. LCD Television
Sharp XL-DK225 Shelf System Logo
877 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
