Question about Kenmore Dryers
Wii not heat
Will not heat up we put a ignitor on and that is not the problim it is gass the modl#97585200
  • 117 Answers
If the ignitor glows and dims with no gas, then it is the gas coils that need to replaced, If no glow, it could be anything from the timer, thermostats, flame sensor or wiring. Ohm the thermal fuse to see if it's open. It may be white and resting on the blower housing.
Posted on Feb 26, 2009
Why is my laptop screen black, and alarm keeps going off
Can you tell me what's you'r modle's lap becouse there are many cases cues the problim and it'diffrent from lap to another.and can you tell me the kind of alarm voice or led and how many times beeb or led.
Dec 11, 2014 | Computers & Internet
Hi would like to know if the dryer modle whirlpool WED5100VQ electric dryer is not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Whirlpool WED5100VQ Electric Dryer
I have a maytag gemini double gas oven and the bottom will not heat up. modle # MGR6775ADW. what might cause this?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 26, 2011 | Maytag MGR6775A Gas Kitchen Range
Kenmore dryer model 97585200 is running but there's not heat
heatman101
Aug 13, 2011 | Dryers
I try install netflix to wii said problem error code 51030
This error refers to a connection to the netflix servers timed out.
Best thing to do here is check your network settings in your Wifi router making sure there are no blocks on the service. Open up pnp ports, imcp ports do help as well.
If the matter does not get relieved, I would call netflix if i where you so they could do some checks on there end.
Regards,
Rulds2008
Jul 06, 2011 | Nintendo Wii Console
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
My gas kenmore dryer #97585200 will run but there is no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.....
Oct 17, 2010 | Dryers
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
Ags761ww: does not heat. need help determining if
most likely it is the thermocouple when it gets hot it tell the oven to open the gass valve
Jun 24, 2009 | Ovens
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
