Can anyone help
Transfer belt fault! Has it been replaced I? Installed correctly? Its the large belt inside the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
SOURCE: I refilled the black cartridge on my Konica
Go outside find a guy with a leaf blower on his back,give him a cold beer, (cerveza-i believe they call it) tell him your problems.
SOURCE: to change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
SOURCE: konica minolta magicolor 2400w
The possible reason for error is the printer does notread chip on the cartridges.
The reader for chips locate inside the printer bottom ofcartridges.
Take out all cartridges and you see reader it is a small blackplastic which come three contact plates.
Just clean it with compressed air and take out if some contactplate is sedentary.
SOURCE: do you know the service
hi........
Konica minolta magicolor 2350 service password is not available.......
pls contact to the customer care..........
thank you.............
Testimonial: "Thanks for the quick reply"
