Question about Safco Telescoping Document Tube, Expands 24-1/2" to 40" Long, 3-1/2" Diameter, Black Graphic Card
Safco Drawing Clamps Missing End Caps
1 have about 25 Safco Drawing Clamps that are missing end caps. I concerned that someone is going to get cut on the sharp edge. How can I get some replacement caps.
  • 1,602 Answers
Go online type in lids or container tops, screw ends, and the size you need and see if you can get any hits or
if you know the manufacture name of product than type in there name and replacement parts
rod
Posted on Feb 26, 2009
I need an instruction manual for the Evenflo Triple Fun model #6231711 (manufacture date unknown - sticker is missing).
Here's an article that outlines the steps for converting the Evenflo Exersaucer to stage 3. It has photos and videos. Also, if you compare your end cap with the ones in the video, you'll see whether or not your end caps were replaced. How to Convert the Evenflo Exersaucer into Stage 3
Nov 27, 2011 | Evenflo Exersaucer Triple Fun Active...
Removing driveshaft to tow 2004 jeep liberty
assuming you have 2wd, just unbolt the clamps that hold the u-joints to the output shaft of the tranny and the input to the differential. The u-joints should remain attached to the driveshaft, but be careful to keep the race/caps on the u-joints so as not to lose the needle bearings. You can duct tape around the joint to keep these ends on. When reinstalling, make sure the caps are pushed in to fit into the recess of the yokes before tightening the clamps. See a picture of the parts to be removed here:
http://images.whisystems.com/smartpages/partinfo_resize/RNB/81018-007.jpg
there are 2 such clamps at each end of the driveshaft.
Please let me know if you have questions, and thanks for using FixYa.
Jul 31, 2011 | 2004 Jeep Liberty
I have a 95 honda shadow vt 600 it runs but its missing on the front cylinder any suggestions it has new plugs new fuel filter and fuel battery is about 2 years old but will run the bike
Try new spark plug caps. The resisters often burn out and cause poor running off idle. On some models the caps are part of the wire and are replaced as an assembly out of the coil. To save money use genuine NGK spark plug caps (about $5 each). They simply screw on to the end of the wire. If the cap reads higher or lower than 5000 OHM's it should be replaced. The copper core spark plug wire can be purchased in bulk for $1 to $2 a foot. It can be cut to length and used as an inexpensive replacement for the stock Honda wire/cap assemblies that sell for $25 to $45 each.
Jun 18, 2011 | 1994 Honda VT 600 C Shadow
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Im having a hard time taking my front shocks apart, i have fallowed the book but there is something that im missing i cant get the iner shaft out
jacke the front of the cycle up under the motor with the cycle on the center stand. The first thing you do after removing the front wheel and axle is to reach up into the lower fork tube with a hex key and loosen the socket cap that holds the tubes to the lower tubes. After the socket cap has been put back in loosely, you can now unspring the fork top caps. The spring pressure from the top caps is necessary to loosen the lower socket screw. The upper and lower triple clamps are the best way to hold on to the fork tubes. The tubes never have to be removed form the clamps. After you unspring the tops , remove the lossened socket caps from the bottom of the forks and slide the lowers off the tubes.
Dec 28, 2010 | 1978 Yamaha XS 650 SE
82 1100 has a bad miss in the upper rpm about 4 to 5000. It even feels like it wants to stall out, someone said the coils.
Old coils have wires that arc and 5000 OHM caps with blown resisters that can cause your problem. You could try replacing the plug caps on the end of the wires (they unscrew) (NGK about $20) Accel makes some bolt in replacement coils for the gl 1000 and gl1100 ($150 to $200). The kit comes with yellow wires and spark plug caps. I substituted snap on Ford truck wires because they were black. With this kit you need screw on tops for spark plugs (Honda snaps there caps on to the threaded plug top with out the screw on aluminum dome). Start your bike when it is dark out side and spray water on the wires to look for shorting. Also, does it cut out in the rain? Your cheapest fix would be to try the new plug caps first, unless of course, the wires are shorting.
Aug 21, 2010 | 1982 Honda GL 1100 Gold Wing
My 650 yamaha specail has a miss fire on the right side not all the time under power it dont do it just at an idle and when you give it a little gas help
There is a resister in the spark plug caps that can cause a problem, try swapping the caps left to right and see if the miss changes side, the caps unscrew off the leads, if there is enough lenght cut 10mm off the end of the leads, when you screw the caps back on
Jun 02, 2010 | 1979 Yamaha XS 650 SF
I have a Eureka 5902AVZ and the brushroll does not work. when i remove the belt, which is not torn nor worn out, the motor spins perfectly fine. Though when i put the brushroll back into place, it shows...
Hi and welcome to Fixya. I am Kelly.
You have correctly identified the problem as the brush roll itself.
There is a bearing under each end cap of the brush roll. You can gain access to the bearings usually by gripping the browah roll end caps and rotate the caps in opposing but loosening (ccw rt / cw left) directions.
Many times I have found that there is just a mass of hair under the end cap that functions like a brake. Clean it up really well on under BOTH end caps.
Do a spin test by putting the end caps back on (Hold it horizontal) and rotating the brush roll with your thumbs. It should spin freely.
If it feels like there is still friction then your probably going to have to take the brush roll with you down to the nearest vacuum cleaner repair / supply shop and get 2 new bearings. Most shops will install the NEW bearings for you if you have the brush roll in hand. It is a much cheaper fix than the brush roll itself.
(buy a new belt too!)
Take care
Kelly
http://www.eureka.com/servlet/ListParts?model=5902avz
Feb 10, 2010 | Eureka 5902AVZ Bagless Upright Vacuum
I live in USA am visiting my mum in Australia. She has a Zeiss Dialy , 7 by 42 B. They are missing the front lense covers or caps - on the larger end - and I was wondering how I could get those for her.
sorry but didnt think zeiss came with them new....they are usually found in cheaper binos as a selling point.....zeiss did have some models with hard rubber caps attached to the objective end so they could not fall off.......enjoy your vacation.....l.reich....www.reichinstruments.com
Aug 08, 2008 | Zeiss Classic 524006 Binocular
Crib locks
if you're missing the lock parts from the ends of the side rails(end caps), I was to. I borrowed the cap from the youth bed rail
since when it's configured as a crib, that rail is extra anyway.
when it was time to go with the youth bed I simply put the end
caps back onto the other rail. GOOD LUCK!
Apr 10, 2008 | Childesigns Carrollton Crib
Safco Telescoping Document Tube, Expands 24-1/2" to 40" Long, 3-1/2" Diameter, Black Graphic Card Logo
127 people viewed this question
Top Safco Computers & Internet Experts
David Payne
David Payne
Are you a Safco Computer and Internet Expert? Answer questions, earn points and help others
