Question about E-Machines M6805 Notebook
Emachine Wont Load Windows
I have a emachine that is unable to boot up. Whenever I turn the power on it stats loading fine and then as soon as it gets to the (windows is starting message) that is were it freezes and refuses to load up.. I have tried restarting it several times and even running the system test but it just will not go any further that the Windows XP screen before freezing. Could you please assist me with this issue at your earliest convience. Much like Delena32's problem, my m6805 (notebook) isn't loading windows and I also have the added problem of not having the boot disk.
  • sheeklouche Mar 18, 2009
    when it gets to the windows xp screen it goes blank for a sec then continues to load again but then automatically restarts the process over and over.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Have you tried booting up in safe mode?
My emachine laptop wont work i turn it on and it comes up with a blue screen then truns off now it only turn on to a black screen and a mouse pointer is there any way to just reset it to what it was when i...
try rebooting the computer and as soon as it turns on tap on the "F8" key until a new boot menu appears, choose "safe mode" if the computer starts successfully in safe mode. restart it and allow to boot normally. If this fails comment back as to whether it started in safe mode or not and I will attempt to help you further,
Mar 02, 2013 | eMachines Computers & Internet
Unable to boot emachine 350
It is possible the battery is an open circuit, so even with the power adapter plugged in there is not enough power to boot the machine. Laptop batteries last about 2-3 years.
Jan 13, 2012 | eMachines eM250-1915 Netbook
My emachine netbook will not load windows, this is a fairly new computer that is less than 3 months old. Computer has not been abused nor has harmful software been downloaded. is there a way to restore to...
firts backup your files .
Restore to factory setting, delete all files
To restore:
Turn on the Netbook
Press Alt and F10
after show options to boot Press Enter
The restore start
Follow the steps
If you can`t restore, Make a recovery disk and restart with the CD
To make CD go to Programs .. Mantenaince -- recovery ..
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | eMachines eM250-1915 Netbook
I am unable to start up my emachine em250 netbook.
The most common problem occurs when there is an incompatible device installed or a device that interferes the boot up of Windows.
If you have recently installed a new device in your computer please remove it and also remember to remove all of the USBs attached to the computer. Basically nothing except the Power source should be connected while you are booting up your computer. You can install the USB devices once your computer has loaded up.
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
My Acer emachine E627 the touchpad doesn`t work. what do?
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Jan 22, 2010 | Acer eMachines 520-2890 Notebook
Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
Nov 18, 2009 | Acer Computer AOA150 Notebook
Replacement DVD-ROM drive
Hi there.
get hold of a boot cd or a windows install disk, set the boot options to boot from the cd drive, if the cd or dvd starts to boot and you get windows loading window then chances are that the lens on the drive is dirty and need cleaning, its also a possibility that the hard drive has bad sectors on it so setup can't write to the disk, hirens boot cd is a usefull tool to check for and recover bad sectors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | E-Machines M5305 Notebook
My emachine M2352 tries to load windows xp but can't do it.
If you press F8 button before XP boot screen then there you can choose safe mode. Can you run XP on safe mode?
Dec 09, 2008 | HP Pavilion zd8000 Notebook
Emachine M5105 that won't boot up.
The laptop is in sleep mode. Take the battery out,then plug in the ac then as soon as you do hit the F3 key and wa la   it wakes beck up..
Best wishes enjoy.........emachines got to love em to play with em  !!
Dec 04, 2008 | E-Machines M5105 Notebook
E-Machines M6805 Notebook Logo
563 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
