Question about Amerock BH26501-G10 Clarendon Towel Ring, Satin Nickel
Missing a mounting bracket from the original package
Does anyone have the brackets for the Amerock Clarendon towel racks? We received a towel rack missing one of the brackets. Does Amerock have a customer service dept. to handle this kind of thing?
    Problem Solver:
  • 4 Answers
Amerock is owned by rubbermaid and they are easy to deal with. try "amerock.com"
Posted on Feb 26, 2009
  • chandler hanley Feb 26, 2009
I'm trying to install a Glacier Bay ceramic towel rack but the instructions are worthless. How does the metal mounting bracket attach to the wall? Does the indented part screw in and and the c
The indented bracket is attached to the wall with screws but should be left loose enogh to allow the ceramic part to slide down over it and seat.
Oct 05, 2014 | Home
The car which carried the transit transporter has been written off in an accident - is it possible to get another female attachment bracket for another car?
the 'female' attachment bracket seems to be either a 1.5" or 2" standard receiver hitch. which you can have installed at most auto or trailer rental shops, such as UHaul... note that you will need the adapter that came with your bike rack to use the 2" receiver hitch
Jun 28, 2014 | Transit Transporter 2-Bike Hitch Rack
Outback Bike Rack Side Straps?
use your own or get strap / webbing and buckles from any upholstery retailer
Aug 20, 2017 | Cycling
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
How to attach book rack to 1984 Schwinn Airdyne
Remove the computer support brackets by unscrewing the bolts holding it to the bike frame. Get 3-4 inch long bolts (to replace the computer support bracket bolts) and nuts that will tighten on the other end and place the book rack support brackets in front of the large inverted U part of the bike frame. Align the holes of the book rack support with the computer support leg holes. Insert and tighten the new longer bolts with the computer legs on one side of the U and the book support legs on the other side of the U. Once you tightne the nuts, your airdyne now has both the computer and book rack on it.
May 29, 2011 | Schwinn Original Airdyne
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
What is the distance from center of metal mounting bracket to center of other bracket for 24 inch ceramic Glacier bay towel rack
Put the towel rack together setting on a table and measure the distance between the two mounts.
make sure you know where the mounting bracket fits into the ceramic peace's.
Feb 03, 2011 | Home
What holds the rack to the car its like its not monted
CHECK RACK AND PINION MOUNTING BRACKETS FOR MISSING OR LOOSE BOLTS.
Oct 15, 2010 | 1992 Lexus Es 300
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Amerock BH26501-G10 Clarendon Towel Ring, Satin Nickel Logo
279 people viewed this question
Top Amerock Home Experts
john h
Tom Chichester
Are you an Amerock Home Expert? Answer questions, earn points and help others
