Question about Compaq (RZ2CC-KA) 4.3 GB Hard Drive
The HDD is not accessible by the operating system Digital UNIX during boot At console mode, the "show device" command does not show it in the list of devices. What is the problem? The DEC part no is RZ2CC-KA and the capacity is 4550MB; the interface is SCSI
  • odwarneo Feb 27, 2009
    The stated solution is actually mandatory preliminaries that were properly configured yet the problem still occurred. Every other setting was correct. Any way I discovered the problem to be the SCSI interface cable from the motherboard to the HDD. I used another cable and the problem was solved. Thanks a lot for your input!
    Actually the stated solution is a mandatory prerequisite that was properly set and configured yet the problem still occurred. Anyway I discovered that the problem was the SCSI interface cable from the motherboard to the drive. I used another one and the problem was solved. Thanks a lot for your input.
  • 294 Answers
Incorrect Jumper setting (SCSI ID)
Each device on the card/controller cable must have unique ID and must be of the proper type for the card/controller...although some like 50-pin SCSI I and II Are interchangeable, larger, newer drives using Ultra, Ultra-Wide and Differential technologies are not.
Typically the controller is set at 7 or 15, so each attached device (CDROM, HDD, Scanner, Plotter, Tape, etc is allowed to use 0-6 or 0-14 depending on controller type.
Doublecheck that you are not trying to use SCSI-Fast, Wide or Ultra controller with the wrong type/technology drive or (gasp) Differential (used mostly for Tape, Robots, Jukeboxes and CD or DVD Arrays) The others won't work... Diff will smoke the drive.
Good Luck!
Posted on Feb 26, 2009
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
How to format a hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Dec 16, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
My toshiba external hdd can t be formatted
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note after you have loaded the operating system you should go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
www.WipeDrive.com
Aug 24, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have a worm in my computer. How can I format the disk?
if you format your hard drive you will need to load another operating syatem on on it
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
if you still want to load another operating system
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Jun 20, 2011 | Fujitsu Siemens (MAN3184MCB) Hard Drive
I have a Western Digital WD1600AAJS drive. It was on a PC, got hit hard by malware. Need to copy off some critical directories from it. Plugged into another machine. Other machine will not fully boot with...
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Jumpers for a PC hard drive are next to the power connector. Mostly in between the power connector and the data cable connector. These are used for setting up Master/Slave settings and also to limit capacity of the HDD seen by PC BIOS on some older hard disks. Usually settings which are selected by jumper setting to various locations are printed on the hard disk information sticker.
hope this helps
Apr 19, 2011 | Western Digital Caviar SE WD1600AAJS 160...
I have a gateway and am trying to replace my current hard drive with the Western Digital Caviar WD400BB 40 GB Hard drive . I currently have 2 maxtor drives in that are op as 1 partition. I hook it up but...
hope this helps
Apr 01, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
My sata 500 gb hdd is hung, office 2010 not working, how can i formatt hdd,(loosing data- no problem, have backed it up already)
you might try this before you format your hardvdrive uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
hope this helps
Dec 03, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Computers & Internet Logo
412 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
