Question about Dell 922 All-In-One InkJet Printer
Print head error
I get message on printer that says "print head error" and nothing works,
what can i do to solve this?
  • 2 more comments
  • Anonymous Feb 26, 2009
    Same thing Print Head Error
  • 4nflk Mar 25, 2009
    I have an HP 2230 and have replaced all the print heads and it still tells me 'magenta print head error' or one of the other print heads. It will occationally work for a half a day or a day, but then the error comes back.
  • inesboricua1 Apr 01, 2009
    my printer dont allow scan and faxes
  • Anonymous Apr 27, 2009
    Any luck with any of these ideas??  I have the same issue.
    Genius:
  • 1,011 Answers
Brand name and model no.?
Posted on Feb 26, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..this problem is due to the printer head.so
clean the head of the printer with the soft cloth.
This will solve the issue..
try this out..
thank u..
rate me..
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Wrong cartridge message
It appears that the problem is not in the ink cartridges at all but rather the print head assembly. Upon disassembly of the print head it can be discovered that the thing appearing to be a logic chip, is probably responsible for several standard commands including cartridge status. One should replace the printhead and then followed the instructions on aligning the printhead. This solves the problem. It can be  bought from Canon for about $45.00 including shipping. Hopes this helps. Thank you, Have a nice day...!
Sep 19, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
U052 error
UO52 error is either a print head temp sensor error or faulty EEPROM data from the print head. You need to re-set the print head. If that fails then a new print head is required.
http://www.tradebit.com/filedetail.php/4588590-canon-pixma-mp960-printer-service-manual
Complete Pixma MP960 service manual from Canon
Sep 24, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Nothing prints
do you have a manual on this printer?
also, see this for more assistance
Apr 21, 2008 | Canon PIXMA MP130 All-In-One InkJet...
FRAGO DTC550 ID MACHINE
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
Dell 922 All-In-One InkJet Printer Logo
350 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
