Question about Emerson MW8102SS 1100 Watts Microwave Oven
Light bulb going out
Oven is 2 years old or so. Works perfect. Light bulb started to flicker off and on yesterday. Stays off mostly. how do I change it and with what type of bulb?
  • 333 Answers
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Posted on Feb 26, 2009
How do you change the bulb inside this microwave oven
Most of the ovens have a fan vent which can be removed, normally the bulb can be accessed through that area. Hope it helps.
Jul 17, 2015 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
GE JEM31SF01 won't work
Check the door switches. There are three of them in most microwaves.
Jul 02, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Mw7300w light bulb keeps flickering.700 w is their a short it is only 2 years old.
see the filaments is there are touching the poles?. use the VOM, in continuity and test it. Yes the bulb can be damaged to due fluctuation On the line,by that reason can be damaged very soon.God bless youb8435993-949d-465e-b16e-2cca8b6fc2f1.gif
Apr 04, 2013 | Emerson MW8168B Microwave Oven
Our microwave worked perfectly yesterday, today when we went to start it, everything was working but it never heated anything up at all. It is 5 years old
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | GE JVM1440 Microwave Oven
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Sharp microwave convection oven model R-930AK. the interior light stays on all the time and the only thing that I am really able to operate is the clock and enter some commands but can not get any...
You do not say how old this unit is, but if the microcircuitry in the door latch is damaged the oven may be unsafe. Service on microwave ovens is not cost effective. For problems other than replacing the light bulb, I would buy a new oven. The prices have become very reasonable and the newer ovens have great new features. I had a Sharp unit for years. I started having problems and replaced it recently with a 1100 watt larger oven for about 20% of the cost of the first one.
Ray
Nov 11, 2008 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
129 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
