Question about Refrigerators
Discolorations/stains on stainless steel refrigerator surface
I have an Amana side-by-side refrigerator with front door ice and water dispenser. Under the dispenser the stainless steels appears to have water droplet like dicolorations/stains that are a light than the finish. There is also a large streak/discoloration on the other door that is much lighter than the rest of the finish. I have tried the standard cleaners and these do not remove the marks/discolorations. As time goes by more of these imperfections are appearing.
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
Posted on Aug 08, 2009
Whirlpool refridgerator side by side is leaking water on the side. We do not know where it is leaking from
Often water leaks result in stains on the Stainless Steel, use DeBruce Polish for removal. Using DeBruce Polish on all your stainless steel will allow you to now perform JUST TOUCH UPS of finger printing and remove the need for "OILS" that manufacturers provide for cosmetic care of blending. Stainless IS A GREAT FINISH TO CARE FOR one just needs the right product. Once cleaned with DeBruce Polish there exists no oil or other "films" to BLEND. DeBruce Polish will now perform touch ups instantly. LOVE YOUR STAINLESS STEEL AGAIN! Get DeBruce Polish at NON-TOXIC AN ODORLESS ...PERFECT
Jan 06, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
stainless steel polish will do this don't get too abrasive a cleaner though,there are different coarsnesses of the product
May 15, 2010 | Jenn-Air JCD2389G Side by Side...
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Jul 01, 2009 | Sub-Zero 642
Leak in the water dispenser
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jun 30, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water stains from dispenser
Debruce Polish works great on stainless steel, polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at
this stuff really works- clean the whole unit and simply touch up there after. Debruce replaced allot of our cleaners and it is eco-friendly!
Jun 10, 2009 | Jenn-Air JCD2389G Side by Side...
Side by side ice maker tray has water stains
Use Lime Away. It helped with mine as the white spots were due to lime in the water. Be careful not to get the lime away on your marble, stainless steel sink, etc. as it will cause discoloration. I found out the hard way. Good luck.
Mar 31, 2009 | KitchenAid Superba Architect KSCS25INSS...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Cleaning tray on door where water is dispensed
the stains is from hard water.(calcium)you can get a new tray from
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Spots on freezer door
Use a product like lime-away may help. These water spots are caused from calcium buildup. Lime-away or similar product will dissolve the calcium. Then use the stainless cleaner on it.
May 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
1,476 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
