Question about Canon NP 6050 Copier
The rollers at the top of the NP6050
Could this leave imprints on the glass that wil cause the copy to show up dark in some places, the places where the dark marks are showing up on the copy are exactly the same place where the marks are on the glass, if so what caused the marks on the glass and why?
Debes limpiar la placa blanca que hay bajo el cristal de copias al costado izquierdo y realizar los ajustes de automatico para que la copiadora haga el balance de luz adecuado para originales claros y oscuros.
Recuerda que desde el alimentador de originales no es necesario hacer ajustes de la intensidad de la lampara. Solamente desde el cristal.
Posted on Mar 01, 2009
    Sergeant:
  • 199 Answers
When ADF is running original through glass, there are some small pickup tyre located inside (glass side) of the ADF are working with pressure to proper handling original on glass to ADF.
So some time later after many page run throgh ADF, the pressure mark is shown on glass.
Replace GLASS
Posted on Feb 26, 2009
A white line runs across each copy.
IF the whit line stays in the same place on every copy all you need to do is clean the left side glass this is called the **** glass i guess you have a top feeder if you place an original on the glass then do a copy you will not get the white line
Also check the developer unit has an even coat on the roller this will also cause the issue you are having
Feb 16, 2011 | Konica Minolta Office Equipment & Supplies
Do you have any instructions on how to clean a Xerox Workcentre 4150. It is leaving a dark streak down the right hand side of the page on everything it prints, not just copies.
First the to do is a "stop test." You will induce a jam before the paper reaches the fuser (which the the hot thing near the exit). The PN for the fuser is 002N02557.
If the defect exists already then the drum or transfer roller or laser may be causing it.
There are very few things that you could clean except the glass on top or the pick rollers.
Whit
Item, Inc.
Aug 23, 2010 | Xerox WorkCentre 4150 Black and White...
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Large black horizontal stripe on copies from Canon ImageClass D760. Recently had ADF and rollers changed.
Sir,
If you place and orginal on the large glass and may a copy does the strip dissapear? If not it could be cleaning blade drum fuser unit? If the strip does leave then you have a problem with the docfeeder glass small long glass next to the big glass. Clean it!
Feb 26, 2010 | Canon Office Equipment & Supplies
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
LIGHT BUT DISTINCTIVE DARK STREEK TOP TO BOTTOM ON ALL COPIES
you do not need to replace the copier
the cartridge has a charger wire that you can clean with a pencil erasure
Also remove glass and clean the underside of the glass and the mirror
finally
open the fuser area( exit area where you clear jams and remove the wiper / cleaner of the fusr rollers
ad reinsert
look for any lines on the rollers
when you install the toner cartridge lift the shutter that exoses the imaging drum to see if it looks ok
if it has lines on it you may have to replace it ther is a wiper (silicone that will get toner nder it and can cause the lnes
All you can do is reinsert ant try it if it persists relace the cartridge
Jan 02, 2009 | Canon PC-795 Copier
Dark horizontal line on canon np6050 copy
Did you try to run the wire cleaning funcation in the add. funcation mode? It could be that a wire cleaner got stuck in that spot and if you Run Wire Clean it may move it bake to Home Position and out of the way... Good Luck
Sep 19, 2008 | Canon NP 6050 Copier
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Bad copies
This seems an easy one the first problem you are getting is that the paper pickup rollers are worn or just dirty easy way to clean them is to place one piece of paper in the tray and at the leading edge spay on some cleaning fluid about a inch wide. Then press the copy button and the machine will jam. Open the door and repeat a few more times. Once finished remove sheet of paper from tray and wipe dry.
The other problem is merely down to dust on the copy mirrors. Remove the top glass normally two screws on the right hand side of the copy glass. Once removed glass place in safe place. In the machine use a cloth on the mirrors you can use windowlene or some other kind of glass cleaner. (DO NOT REMOVE MIRRORS) clean all then clean glass and replace the copy should be clean. (NOTE!!!!! There should be about six mirrors so make sure you clean them all)
Oh and be careful machine should be off when doing above.
Hope this helps
J
Dec 25, 2007 | Office Equipment & Supplies
Canon NP 6050 Copier Logo
99 people viewed this question
old marine
old marine
