If you need a tech please visit U-lines website www.u-line.com and under customer service you will see service locator. That should give you a list of companies.
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part...
(More)
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part number. Can you help?
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet,...
(More)
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet, plugged the fridge into another outlet it sparked till I cut the electricity. what could cause this?This is a built in , and I saw no signs of dirt or other debris that could of caused a problem. It is a uline 75R
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating...
(More)
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating element, or the circitoard, or what? thanks p.s. its a 1978
There is a small ledge container on the back wall of the fridge which extends across almost the full...
(More)
There is a small ledge container on the back wall of the fridge which extends across almost the full width and this is full of frozen water. Water now leaks out from botom of fridge. I am presuming the hose that drains this container comes from that ledge container. Also the container on the back of the fridge (on top of the compressor) is totally dry. I am presuming that this is the cycling part of the defrosting process. The fridge seems to work quite well other than that. Any clues? Or can you tell me how the defrost process in these works?
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same....
(More)
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same. Can you advise how to plug it in. New one has 4 wires old one has six
