Question about Thermador 37 in. CEP365 Electric Cooktop
Discoloration on my thermador ceramic cooktop
Help! My teenage son put an empty Cusinart stainless steel pot (with copper layer) on my beloved Thermadore ceramic cooktop, turned the burner on high, and forgot about it. The pot is scorched and my cooktop has a gray ring around the burner which I can't remove. Before he fessed up to what had happened, I thought it was a simple boil oil, so I went after it with cooktop cleaner and then a razor blade. This of course didn't work. Is there anyway to remove this discoloration from my cooktop? If not, is it possible to replace just the glass? Is that expensive? The cooktop is only about 4 years old and I didn't have so much as a minor scratch on it. I haven't tried to use the burner yet because I don't want to make things worse. Will I be able to use it?
  • 679 Answers
better you use a new in place of old one.
Posted on Feb 26, 2009
I have a hole in my ceramic thermador induction cooktop
You really can't. Ceramic can be repaired but it can be short term. There may be a sealer they can put in the opening.
Jan 02, 2013 | Thermador 36 In. Silver Induction Cooktop...
I cannot get my burners on my stainless steel gas stove top clean
What I would try. Assuming the "burners" means the cast iron assemblies on top of the stainless steel, remove them to an area outside. Perhaps on a piece of plywood, and clean them with oven cleaner. Grease may drip off them, so a deck or driveway are unacceptable. Wear gloves and watch splatters. Wash thoroughly with fresh water before reusing. Beware. Caustic chemicals can discolor stainless
spencer
Aug 20, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Cooktop locked
May I get the make and model # of the cook top to help you more.
Jul 06, 2010 | Thermador CIT304ES (Electric) Stainless...
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
I have discoloration on my kitchen aid stainless steel oven top on the strip of stainless just above the controls. I have tried vinegar, baking soda and dishwashing liquid, oven cleaner(not heavy duty Easy...
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 22, 2009 | KitchenAid Cooktops
Discoloration around burners
the discoloration is from the heat. you can buy a stainless steel cleaner or use simple green for the grease.
Jul 20, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Mar 20, 2008 | Thermador PSC364GDZS Gas Cooktop
How to clean the stainless steel stove top
try a non abrasive cleaner like bartenders helper. it wont scratch and should help to tone down some scratch marks.
Aug 04, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador 37 in. CEP365 Electric Cooktop Logo
220 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
