Question about Bosch Washing Machines
I just bought my second set of Bosch washer and dryer. This washer - WAS20160VC - does not have a choice for water level. Does the washer use the appropriate amount of water according to the load bautomatically?
    Sergeant:
    Champion:
  • 289 Answers
Hi..ya it uses the amount of water automatically. ENERGY STAR® qualified Washer must plug into a Bosch Dryer or a 240 Volt outlet 3.4 cu. ft. capacity largest in 24-inch footprint Unique stainless steel structured drum Electronic touch control Maximum spin speed: 1000 RPM Sensotronic Plus? (dynamic load sensor, digital temperature sensor, continuous suds sensor, unbalance sensor) Internal water heating element provides 6 guaranteed water temperatures up to 161 degrees Stackable Color:White Capacity (Cu. Ft.):3.4 Number of Wash Cycles:15 Number of Rinse Cycles:5 Delicate Cycle:Yes Energy Saver:Yes Permanent Press Cycle:Yes Heavy Duty Cycle:Yes Wool Cycle:Yes Soak Cycle:Yes Prewash Cycle:Yes Cotton Cycle:Yes Handwashable Cycle:Yes Knits Cycle:No Extra Spin Cycle:Yes Number of Wash Temperatures:5 Number of Rinse Temperatures:5 Number of Wash Speeds:4 Sound Reduction:Yes Control Type:Electro-Mechanical Bleach Dispenser:Yes Fabric Softener Dispenser:Yes Tub Material:Stainless Steel Lint Filter:No Height (Inches):33-1/2 Width (Inches):23-3/5 Depth (Inches):22-1/4 Energy Star Compliant:Yes Manufacturer's Warranty (Parts):Limited 2 Year Manufacturer's Warranty (Labor):Limited 1 Year check this out.. thank you..
Posted on Feb 26, 2009
  • Hariharanath V Feb 26, 2009
    hi..it doesn't have any option to select the water
    level.It is fully automatic with internal element.
    check it out..
    thanks..
  • 13,433 Answers
Yes most washers automatically adjust the water.
  • Ekse Feb 26, 2009
    Todays washers have a Automatic load adjustment system.
Water pump not working hoover 520l
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 25, 2013 | Hotpoint WD62 Front Load Washer / Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Vision 800 Series front loading washer. Flashing "water level is too high". We are not getting any water into machine at all. Is there a way to reset?
We had this same problem last night, although we had just purchased this washer 'new' (bought it at Sears, display model, and it's 9 months old but had not been used). We didn't even get the correct user's manual with it, but after running one cycle without laundry the message went away.
Aug 09, 2010 | Audiovox Bosch 718 World Cellular Phone
Bosch classix washer dryer has just flooded water through its door and drawer whilst on a cycle. Any suggestions?
Several possibilities.
  1. Was water poring out of the drawer when the appliance was in spin?if so then possible cause is that the appliance hasnt draqined its water first. It is trying to spin with water in drum and it has to go somewhere.
  2. Is the appliance overfilling? Water level should just come to the bottom of the door but if you see it rising up to the top of the door then you have a problem with the water level sensor (or a blockage)
From experience with the type of fault you have i would say that its not draining all the water before spin. If you have a pump out function then do this a few times until ALL the water has drained. put a large towel in front of bthe filter and unscrew filter cover and check for a blockage.
If you cant find anything then you may need to call a engineer
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hot water
new washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
Jun 09, 2008 | Crosley CAWC529JQ Top Load Washer
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Jan 19, 2008 | Washing Machines
WFT 2800INSTRUCTIONS
http://www.bshappliancecare.com/Bosch/ click "instruction manual download" type WFT in the search box, and you are taken to the downloads page - sorry i couldn't link to it directly. Hope this helps :)
Feb 09, 2007 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
