Question about Intel D865GBF Motherboard
I can't connect to the wifi even in taskbar it shows that wifi is connected and signal strength is also very good. mine is acer aspire 3680. please help. also tell how to install lan drivers.
    Sergeant:
  • 175 Answers
Hi Dear. Verify DHCP or Manual IP configuration from AP/WIFI Router. Disconnect and Reconnect and follow IP configurations as mentioned in AP/WIFI Router.
Posted on Apr 14, 2009
Why will my Acer Aspire 5552 running W7 only connect to the internet when it's near the router? When elsewhere in the house, it shows 2 bars on the signal strength, but will not connect to the rou
That means you have a crummy internal wireless card. Your best bet would be to purchase a USB wireless card and your problem will be solved.
Mar 21, 2012 | Computers & Internet
I have a vga to hdmi cable for my acer aspire 3680, when I connect the laptop to the tv with the cable, nothing happens. neither device sees the other or even registers that the cables are connected. is...
VGA has only analog video signal. It is not digital and does not have any audio either.
HDMI is a digital connection standard with both digital video and digital audio signals.
A cable with a VGA connector on one end and a HDMI connector on the other still needs a converter box to convert the analog signals into the digital signals required for the TV's HDMI. Click on the following link to go to web page titled VGA to HDMI Cable - An Unfortunate Myth
http://vgatohdmicable.info/
Apr 21, 2011 | Acer Aspire 3680 PC Notebook
Hi signal strength is excellent but connectivity is limited or none any ideas???
Your router isn't set up properly, or your have no internet. ring your internet provider
Mar 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
The wifi is turned on but there is no wifi icon at the bottom panel of my netbook. i cannot locate the connection management settings.
in control panel go to network settings you will find it in there right click on the wifi connection and go to properties, click the check for show when connected in taskbar then that icon will be on your taskbar at the bottom
Jan 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Im having trouble connecting to internet with aspire one acer wireless net connection status: limited or no connectivity, but shows 54.00 mbps and a strong signal strength, how can i fix this
Is this happening when connecting to your home network or at public wifi sites? Check the network connection icon in the lower right hand part of your screen (called the system tray), right click on that, and it should have a popup that says "connect to a network" click on that, and a list of available networks should be listed. Many public wifi sites are security protected, so make sure you have the appropriate user name and password for the site you're using. If the site is listed, left click on that to highlight it, then click connect at the bottom of the window. That should establish a connection with a local network. If problems persist, download and install a new copy of the network driver software (available from the manufacturer). Good luck!
Dec 22, 2010 | Acer Aspire One PC Notebook
Wireless connection will not turn on has x ove signal strength tried using window flag plus x shows icons all work except wireless con wont turn on
Hello
I am going to assume that you never had wireless connection with your 3680. With that in mind, Go into Control Panel to make sure your wireless connection can "see" other network routers. Control Panel>Network and Internet Connections>Network Connection. When you start the search for networks, this should turn your wireless adaptor on to perform the search. If you get a message that you do not have a wireless adaptor, use the Wireless Network Setup Wizard.
Good Luck
C2Solutions
Oct 19, 2009 | Acer Aspire 3680 Laptop
Need drivers for laptop mainly network drivers
You can download latest device driver for all acer aspire laptop models including your aspire 3680 (both XP and Vista drivers available) @ http://www.downloadya.com/files.php?cat=4
May 28, 2009 | Acer Aspire 3680 Laptop
Intel D865GBF Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
