SOURCE: fridge not working
check the owners manual if not im suspecting some sensor has to be defective.
SOURCE: Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to
in the bottom of your freezer when it goes through the defrost (removal
of ice from the freezer coil) cycle. It sounds like that hole is
plugged and now the water/ice has now frozen in the vent that lets air
circulate down into your refrigerator compartment. What I usually do in
this case is to unplug the refrigerator, empty out the freezer
compartment. Usually I also end up either pulling off the back panel or
the bottom panel (in the freezer compartment) Looking for that defrost
drain hole and thawing it out with a heat gun (be careful of melting
plastic) or actually I use a hair dryer. I can sometimes do this also
by pouring small amounts of HOT tap water onto it and then
sopping/absorbing it away with a sponge or dishcloth. I repeat this
until I get the water to go down the drain tube.
Try it and let me know!
SOURCE: my fridge is warm, the frezzer is cold but not
Hi, Look inside the freezer and see if there is frost building up on the rear panel inside. If there is frost, Remove the rear panle and check the defrost heater and bi-metal switch (must be tested while cold) for continuity, If either of these switches show an open circuit, replace it.
If these parts test ok, replace the defrost timer.
Other things to look for, make sure fans and compressor are running.
Please let me know if this helps or if I can assist you further.
Vic
SOURCE: I just has the motherboard replace last week and
You don't say why the mother board was replaced. Make sure the board was the correct one, part number WR55X10656 for your GSS22WGMD and that all plugs are firmly and correctly attached to it. If yes, then check the defrost heater (located behind the back wall inside the freezer, near the bottom) to see if it is burnt out. (If you disconnect the wires from each end of it and test, finding no continuity, it is bad) It is a part number WR51X10101 for your model, and is a fairly common failure point. While you have that apart, manually defrost the coils with a hair dryer. (the manual defrosting alone will get your refrig working for at least a week, allowing you time to get any needed parts.) If left alone without defrosting, your freezer section will not be working well soon either.
SOURCE: ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
