Question about Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard
I'm using a set-up with a Gigabyte 7VT600P-RZ motherboard, Athlon Sempron 2300+ CPU, and an Nvidia 7900 graphics card. It's been running fine for several years, but has faced increasing problems with booting up Windows XP recently, regularly dropping to the CHKDSK diagnostic screen. Last night, after another such diagnostic screen, it began a cycle of reboot, get to the Windows loading screen, flash up a. BSOD too quickly to read, then reboot once more. Turning it off for the night, I switched it on again this morning, but now there is nothing happening - power goes through all the components, drives spin up to speed, but there is no output to the monitor, and no boot-up 'beep' - it just sits in that limbo state. Is this a recoverable problem, or has my system finally given up?
  • jonthecelt Feb 26, 2009
    unseating and reseating the RAM has allowed it to boot once more, but am unable to progress beyond the windows loading screen - still getting the flashed up BSOD, then back to boot-up.
  • 13,433 Answers
Check the motherboard for bulky capasitors or leaked capasitors, and begin with disconnecting everything that isn't needed for the computer ot function (cpu, fans, motherboard, 1 memory module, video card)
Posted on Feb 26, 2009
  • Ekse Feb 26, 2009
    These components are required for the computer to function - cpu, fans, motherboard, 1 memory module, video card.
    so disconnect everything else and see if theres any improvement.
    If there is no improvement, remove all the ram from the computer.
    Then try starting up without any ram, the computer should beep.
    (remember to unplug the computer when your taking parts out or in)
    Now, replugin one ram module and try starting up again. Does it beep? do you get video?
    If you don't next, lets reseat the video card, remove the video card from the computer and start it up without a video card, does it beep?
    Turn it off again and reinsert the video card, try starting up again. Results?
    Ones you have done all this use the add a comment link below to let me know how its going, reposting will get another expert.
    Thanks,
    Ekse
  • Ekse Feb 26, 2009
    Keep tapping f8 before the windows xp logo comes up, then from the advanced start up options select disable automatic restart on system failure.
    Now when you get the bluescreen again can you tell me the Details it gives you? or possibly you could take a picture of it?
How To install Win 7 on 7VT600P-RZ
There are no Gigabyte drivers for this motherboard under Win 7.
Use the default Win7 drivers for the VIA 600 chip set.
If the default Win7 drivers do not work, (A 0.1% chance), the solution is LINUX.
Jun 15, 2014 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
Gigabyte 7NF-RZ board is fried. Replace it with? Same board or is there a better way to go
Take same hardware like CPU and RAM in to consideration. Make sure these are compatible. This is where a whole new system takes root.
Nov 28, 2012 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
I have a Gigabyte 7vt600p-rz motherboard. How do i disable the Bios Security password on it so i can change the boot sequence ?
Clear cmos, you should have a clear cmos jumper on your motherboard, just move the jumper from the normal position to the clear cmos and then back. Or you can remove the lithium battery for atleast 15 min.
Nov 17, 2010 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
Any. I got old one amd processor of 1,2 Ghz and I am looking around what I can do before I done this old pc to my kids. motherboard is 7vt600p-rz of gigabyte
Windows 2000 SP4 will run faster on it, if it is with XP. Win 98Se is just a sadistic idea. As for hardware, nothing cost-effective imho. SDRAM is really expensive, even if you have a free slot. This CPU will not utilize more than 512MB/1GB anyway. Even if faster CPU is supported, it is probably not worth again. Still, check on e-Bay if you enjoy the upgrade. Overclocking is not the strong side of AMD. But if you ask around your friends and get a RAM or CPU, or HDD at 7200 rpm for the OS (yours might be 5400 rpm), which they will never use for low or no price, things change. You can also do a fresh install.
Nov 08, 2009 | Gigabyte 7VT600-RZ (GA-7VT600-RZ)...
The best sistem for k8v-mx
Supports AMD Socket 754 Athlon 64/ Sempron processors, here is a list of processors supported by the motherboard >>>>
http://www.cpu-upgrade.com/mb-ASUS/K8V-MX.html
As for the graphics, the board supports PCI Express graphics cards, its up to you which card to buy, you can either purchase Nvidia Geforce 9 series or ATI Radeon HD series.
Regards.
Aug 01, 2009 | ASUS K8V-MX Motherboard
Athlon 2800+ XP-M runs at 606 MHz
1. Check your battery, 2. Press CTRL+F1 or ALT+F1 while you are in the BIOS. 3. Update your BIOS Microcode and CPU Code.
Sep 20, 2007 | AMD AXMJ2800FHQ4C - Athlon 2800+ XP-M...
Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard Logo
29 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
