Question about Tools & Hardware - Others
No problem-just want info
Looking to buy a coleman furnace model DGAA077BDTB MOBILE HOME FURNACE.WANT TO KNOW IF IT IS PILOT OR ELECTRONIC IGNITION.
This unit is electronic ignition
Posted on Oct 04, 2009
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
I JUST BOUGHT A USED COLEMAN EVCON FURNACE MODEL #BGU09516 AND I NEED TO KNOW HOW TO VENT IT. PLEASE HELP, THANKS
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Furnace gas pilot light keeps going out when windy outside
Honeywell makes an electronic ignition conversion kit. (White rodgers also has one but it uses a mercury switch which can be expense if it goes bad). A good service man can install the "Honeywell Y86 Universal Intermittent Pilot Retrofit Kit". This is a "complete" kit for converting a standing pilot system to electronic ignition. It includes a new gas valve, ignition cables with connectors. ignition module and a pilot assembly. It does not include pilot tubing (pilot tubing is cheap). This kit also comes equipped for either natural gas or propane. Your heating guys probably don't know about it because they are to young and not familiar with the old days. Or they just don't care and would rather sell you a furnace. I think that they just don't care. I live in Ohio I just opened up the "new" Johnstone Supply catalog. This part is "not" outdated its on page 450. Do not let these heating guys buffalo you into a new furnace. You are to smart for that! If you weren't you would have believed them and bought something you don't need. Instead of researching on the internet.
The bad news is this kit lists for $456. plus labor.
Nov 20, 2008 | Heating & Cooling
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
Tools & Hardware - Others Logo
188 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
