Question about Sunfire True Subwoofer Mark IV Subwoofer
No Power My sunfire true Sub has not power. I replaced the fuse to no avail. Niether the little green standby light or the power lights on the eq come on at all.
  • tropicalland Mar 02, 2009
    My tru sub eq 10 has no power. I have replaced the fuse in the back rt corner to no avail. Is there an internal fuse that can be replaced? Do I need to send it back to sunfire?
  • 6,784 Answers
Replacing the power board will fix this amp/sub combo. Seems to have blown a cap or two.
Posted on Mar 02, 2009
  • Michael Masters
    Michael Masters Mar 02, 2009
    I suggest shipping or transporting to your local tech shop for repair. this will require a qualified tech.
  • 19,396 Answers
If the unit is still on warranty, then send it to Sunfire, any repair may invalidate warranty.
If unit is not covered, then the problem is probably one of the capacitors on power board. You can have it repaired at a local electronics.
    Top Expert:
  • Sunfire Master
  • 79,077 Answers
If the fuse was blown then there is an internal short in the sub's amplifier circuit, if it is under warranty send it back for repair.
  • 13,433 Answers
Hey, first test the powersupply and see if its giving out what the sub needs in order to function. Also check all the fuses in the unit. Is the powersupply working? do you see any burned or bulky components / faulty components?
Posted on Feb 26, 2009
  • 77 Answers
Hiya
if u change the fuse inside the actual sub shud power up ok
Rik
Own a Sunfire True Sub MKII, light on but no bass, when volume on all the way it barely hits. Fuses appear to be ok.Circuit board looked ok I dint notice any blown caps or miscolored resistors. Help?
Start with the volume way down on the sub.
Connect the line out of a source you know is working with cables you know work to the inputs of the sub. Try left and right.
This will let you know if the problem is in the sub or the output you're trying to use.
Oct 05, 2015 | Sunfire True Sub MK II Subwoofer
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
Hey, I hope someone could help me out! I got a sunfire EQ 12 true signature subwoofer. It worked great at beginning. However, the issue is auto off. It will turn off after a few minutes no matter for...
Auto-off will be a software issue, so no, you can't turn it off. Send it back as a warranty repair. They have a 1, 3, or 5 year warranty. Look at the the support page. Also shows factory repair.
SUNFIRE True Subwoofer EQ 12 Signature TS EQ12
Jul 29, 2017 | Audio Players & Recorders
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
Blown Driver Sunfire MKII True Sub, looking for replacement woofer.
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-460&ctab=2#Tabs
Jul 02, 2009 | Sunfire True Sub MK II Subwoofer
Got power..but no sound
Your sub may have gone into protective shutdown to prevent failure as a result of "thurderous (sic) performance".
Mar 18, 2017 | Sunfire True Sub MK II Subwoofer
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Has light but no sound
The first thing to always check first is the fuse. This will probably involve some disassembly but it is alwayst the cheapest fix and a constant issue.
Aug 14, 2007 | Sunfire True Sub Signature Subwoofer
Sunfire True Subwoofer Mark IV Subwoofer Logo
477 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
