Question about Procom ML300HGA Heater
Pilot Lught I'm having problems keeping the pilot light going on initial start up. The pilot lights fine but it doesn't make any difference where the control knob is, it (the pilot) will not stay lit. I've tried "fudging" a little each way on the setting, still no luck - the pilot simply won't stay lit when I release it after initial warm up of the pilot. Has anyone else had this problem and what was your corrective action??
    New Friend:
The theropile is connected to tha safty valve .the switch inside is magnetic and can stick. Light pilot and try tapping on it with handle of a screwdriver. Otherwise the valve can be replaced .
Posted on Jan 31, 2015
  • 686 Answers
When you light the pilot you hold down the knob for the coupler to get hot at this time don't let go of the knob turn it to on position as quickly as you can. If that doesn't fix it you need to replace the thermal coupler. try that
Posted on Mar 01, 2009
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot LIGHT KEEPS GOING OUT OUT
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. If the pilot light has only a weak flame, the whoosh of the main burner igniting can quite often blow out the pilot. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If pilot flame goes out for any reason, it shuts the gas off to the pilot jet to prevent unburned gas collecting and causing a safety hazard. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced.
Oct 29, 2010 | Heating & Cooling
Pilot l.ight will not stay lit
Oct 20, 2010 | Whirlpool Water Heaters
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
Oct 08, 2010 | General Electric GE SmartWater Household...
We have an intertherm heating system, its probably 30 or more years old, and we cant see a pilot light, and we havn't been able to light it. the model is mac 1175.
Sep 27, 2010 | Intertherm Heating & Cooling
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Procom ML300HGA Heater Logo
430 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
