Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do change a cartridge when none are empty?
I have just replaced my black cartridge with a new compatible one, however it wont print properley, it is just printing a couple of dots. I believe its because i didnt shake the cartridge before changing it, and therefore it has an bubble or is clogged, how do i get it back out if the ink light is not flashing?
Whenever i print not too clear
Posted on Feb 26, 2009
Cannot print an alignment scanner page
Symptom that black cartridge faulty, if warranty applicable get replacement, if no clean cartridge nozzles through printer drivers properties>service>clean nozzles... try..
Nov 15, 2011 | HP DeskJet F380 All-In-One Printer
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Epson C64 will not print
well it is the chipset on the compatible cartridge. it is not good.
try another one ..
Jan 11, 2008 | Epson C64 InkJet Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
