Question about Miele Novotronic Premier 500 Front Load Washer
Miele Novotronic Premier Plus - no water into the machine
We in herited this machine which has been fabulous! But the check water light is flashing and only a little bit of water appear to be getting to the machine. I have checked the main water pipe and it is fine and the pipe seems to fill up but obviously doesn't get into the machine....
Help.
  • 1 more comment
  • sarah714 Mar 02, 2009
    How do I remove the hose from the washing machine end?
  • sarah714 Mar 03, 2009
    It is very helpful and very much appreciated! I am a new user and the e'mail had a link asking if the problem had been solved...
    I will go and unscrew the hose and let you know how I got on - again thank you for all the advice.
  • sarah714 Mar 06, 2009
    Many thanks for all your help - in the end ot was the outlet valve so no amount of meddling by me very well advised by your could help! Fantastic that you gave me the confidence to have a go though.
    MANY THANKS
    Scholar:
  • 106 Answers
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Posted on Feb 27, 2009
  • fixer444 Mar 03, 2009
    One end is screwed to the wall faucet, close faucet and unscrew this hose to examine the fine mesh. Then unscrew the other end, the end that connects to machine; examine here for debris as well as on machine mesh.
    If these or okay & you still have problem remove the top cover & you will see how the hoses come into the dispensing tray, check these out. Caution reconnect carefully, so they dont leak.
    These are free solutions, so pl give me some good rating, its too late now you've already clicked...............
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Main wash light flashing
I have the same problem, try checking the water temperature, it seems that this light indicates a heating ciruit problem. The next step is to check continuity of heating element. These are readily available from meile and other suppliers/ aution site on web.
Nov 30, 2012 | Miele Novotronic Premier 500 Front Load...
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
407 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
