Lakewood ep2000 shows power but won't heat after moving unit
I moved the unit to another part of the house. It was working when I moved it, but wouldn't heat up when I plugged it back in in the new location. It shows it has power, but doesn't heat. I have left it unplugged for a few minutes, but it still won't heat.
  • 34 Answers
Visit this page for service center and parts info.
Posted on Apr 18, 2009
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
2006 Dodge Durango - Fuel gauge stuck on full, and won't move? What's wrong?
Either the circuit is shorted to ground, or shorted to power.
The sending unit in the tank provides ground to the gauge.
I would disconnect the harness at the tank and see what the gauge does. You may need a new sending unit.
Jul 30, 2012 | Cars & Trucks
My Lakewood oil-filled electric radiator makes some crackling noises when first heating - is this normal?
Yes, it is normal. the sound is from the oil heating up and moving through the fins. It will stop after a few minute. After the heater is used for a few months the noise will stop altogether. j
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Feb 22, 2011 | Lakewood Oil-Filled Electric Radiator...
My lakewood high speed floor model HV-21T stopped running. After shutting off it started running again but shut off again and this time the motor and cage was extremely hot.Also are new motors available on...
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
Aug 22, 2010 | Lakewood HV 18-c Floor / Box Fan
Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Apr 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
Deck top got pack up for new house and dose'nt won;t to cotackme on green light flashes in the back but no power to the s
prob:no power to mainboard
solution: Take cover off the side of unit find memory modules and reseat the mem sticks also find power harness usually clear or white w/ plug goin to main board unplug and reseat try to power up!
Apr 17, 2009 | Computers & Internet
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
