Question about Baby Lock Ellure
Baby Lock BMP6 message: "Check upper and bobbin thread"
I have a message: "Check upper and bobbin thread" @ my baby lock BMP6 embroidery machine. Message come when i try to run 2,3,4,5 needless the 1&6 working good.Also I can't adjust tension at needless 4 it too loose. If some body have any idea I'll really appreciated. Tym
SOURCE: baby lock quest, blq2 bobbin problem
is the needle bent?
Posted on Feb 20, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Posted on Sep 30, 2009
yeroc
  • 397 Answers
SOURCE: Baby Lock BL3-406 tension setting messed up.
set all to 3-4
Posted on Nov 27, 2009
SOURCE: I have a Baby Lock BL4-736D serger. I need the
orange-(5-7)
yellow-(4-6)
green-(2-4)
blue-(2-4)
medium weight, 4 thread
Posted on Feb 09, 2010
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
How do I adjust the bobbin tension on baby lock elure plus
The owner's manual provides instructions for adjusting the tension by manipulating the upper tension to either tighten or loosen the upper thread:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjo876NhNjJAhXhqYMKHQyGABEQFgggMAA&url=http%3A%2F%2Fbabylock.com%2Fftp%2Fwhitepapers%2FEllurePlus_BLR3_InstRefGuide.pdf&usg=AFQjCNFjueCqjBE7C9yxi3qeIhkkLrvomg&cad=rja
However, here is a discussion about adjusting bobbin tension:
http://www.embroideryforum.com/forums/showthread.php/13579-Babylock-Embroidery-Machine
Be very careful adjusting the bobbin tension as it is very easy to over-adjust.
Dec 13, 2015 | Baby Lock Sewing Machines
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
How do I override the hoop size on my BMP6 Baby Lock Embroidery Machine?
There are limits....check your manual first, or call a dealer
Feb 17, 2014 | Bernina Bernette Deco 600
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Sewing Machines Logo
572 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
