Hotpoint aquarius wd440 confusion over washing machine pipes
This question is about a hotpoint aquarius WD440
in the machine only supposed to have the blue inlet pipe at the back (i.e. no red pipe). i've bought one second hand and it only has the blue pipe!
    Scholar:
  • 86 Answers
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Posted on Feb 27, 2009
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 1400spin. How long can the vent pipe From the Dryer be ???
If it is washer dryer, then it does not need ventimg, as it is a condenser type dryer, which condenses the steam back to wate therefore no hose neededr
Nov 01, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Hotpoint Washer/Dryer,Aquarius WD440 will not take softener.
take out small either blue or green filter from detergent drawer where you would normaly put the liquid softner and run it under hot water tap my guess is that the small pipe within is clogged this should clear it
Oct 13, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
204 people viewed this question
Top Washing Machines Experts
