Question about Cameras
Hi there, My canon Mv630i Tape cassette loading mechanism is not working right. The carrier which holds the tape cassette rises up ok but the side part does not spring open to allow a cassette to be put in. It waits for a few seconds and then descends to the ready to shoot position.
  • 1 more comment
  • v_tbell Feb 26, 2009
    Hi there I dont' know if I am replying to the right person as I can't find any reply tab to click but the camera is 1995/6 vintage although it has not had a lot of use.
    v_tbell
    Hi again,
    The camera has never been dropped to my knowledge. It was sent for repair when it was under warrenty for a electronic fault This was at switch on, nothing but coloured vertical lines appeared in the view finder and screen. It was repaired and worked ok until recently it started to object to releasing cassettes and finally refuses to open to accept a cassette at all.
    v_tbell
  • v_tbell Feb 28, 2009
    Hi again,
    So the best advice is to send it for repair ? Is there no one who has had this problem before and solved it?
    v_tbell
    President:
  • 1,952 Answers
    Genius:
  • 1,011 Answers
Sir,
Do not expose the camcorder to wet or hot conditions. Condensation can damage the camcorder. ... Loading and unloading a cassette
Here click this link to solve your problem
Thanks Good Luck
Posted on Feb 26, 2009
  • 744 Answers
Hi try to do the followin steps...
Reset your camcorder back to factory defaults to attempt to correct this issue:
1. Remove the power adapter, main battery and the backup battery.
a. The backup battery is located behind the main battery.
2. Let camera sit with no power for about 20 minutes.
3. Replace batteries and power adapter to your camera.
4. Power on your camcorder and attempt to load a new tape.
Sometimes if the camcorder is exposed to an environment with high humidity, it is possible for moisture to produce inside of the unit. As a safety mechanism, DEW will flash in the viewfinder (however this error message does not always display), and the camcorder will not load a tape. If this occurs, the camcorder should be taken into a cool dry environment.
The playback and/or recording heads may have dirt or tape particles lodged on them. Try using a dry head cleaning cassette (never use wet type). You can obtain a dry head cleaner at any local store that carries electronics equipment.
If you are unable to load the tape, then verify that there are no obstructions in the compartment, keeping the tape from loading. If there are no obstructions, then the camcorder may need a Tape Path Alignment, or the posts may be loose. This would require servicing to resolve the issue....
thanks
rate me!!
  • 121 Answers
I would suspect that the mechanical portion of your loading mechanism is dirty and binding up. If you watch all of the moving parts your should see places where a qtip and a little bit of rubbing alcohol could be used to clean the mechanical interfaces. A good swabbing to the tape head won't hurt anything either.
    Sniper:
  • 90 Answers
Http://www.free-service-manuals.com/Detailed/71828.html
here can get the service manual after registering...
  • 95 Answers
The spring inside is stuck which is not getting extended and hence it does not function properly. You have to open it and check which would not be possible unless you get it serviced. If its under warranty, contact canon or your local dealer and get it serviced or repaired under warranty. If we try to troubleshoot, it might get further damaged and void the warranty, if there is one.
  • 495 Answers
You need to repair it from your dealer if its under warranty.
  • Manoj Rout
    Manoj Rout Feb 26, 2009
    Chances are it is in need of a major cleaning. Usually by the time this
    happens the cleaning tape will do no good. A good internal cleaning is
    usually the only thing that will help it........Has it been droped? If
    it has then you could need repairs
  • Manoj Rout
    I think the is some problem with the spring which got stuck and it is coming up now. Better take it to repair shop otherwise you will end up in damaging it more.
  • 13,433 Answers
First off, is the camcorder covered by warranty? Warranty repairs by canon would be your best choice in that case.
let me know.
Thanks
  • Ekse Feb 26, 2009
    There doesn't seem to be a repair/service manual available for this model, old camera I'm not surprised.
    Basically if the cassette door doesn't eject. we will need to eject it manually. First I'd suggest to try helping the cassette door eject, use a flat small screwdriver and try to help it to open.
    If this doesn't help at all, we may need to take the camcorder apart and find the problem with the eject mechanism, unless another expert has documents for this camcorder you would have to go in blind taking it apart part by part.
    Instead I would suggest considering taking this to a professional repairer.
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette....
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Oct 13, 2010 | Panasonic NV-HD680 VCR
Canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
May 15, 2010 | Canon MV800i Mini DV Digital Camcorder
I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
Dec 19, 2009 | Canon Elura 65 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
TAPE COMPARTMENT KEEPS POPPING OPEN
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
Bluelikealex :o)
Oct 31, 2007 | Video Cameras
Cameras Logo
127 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
