Question about Griffin Technology Audio Players & Recorders
IPhone Griffin Adapter Broken
Is there a way to fix my Griffin iPhone Adapter? The wires have clearly snapped inside their casing, from the Adapter wire bending and breaking from when I listen to my music and have the iPhone in my pocket.
Is it a case of cutting the adaper wire, paring back the insulating plastic, reattaching the wires? Or is this even possible? (The break is right next to the plastic jack head)
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
SOURCE: DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Posted on May 02, 2009
SOURCE: Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Posted on May 28, 2009
  • 34 Answers
SOURCE: Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Posted on Sep 19, 2009
  • 10 Answers
SOURCE: Needle breaking, hitting bobbin case
I had this problem and it is very easy to fix!
With mine I looked at it for about half an hour, and all I needed to do was put the bobbin case back in,(how it fits normally) and then hold it and turn it anti clockwise until it clicks, it may be quite pressured to do but ive heard a lot of people having this problem and thats all that needed doing!
Hope i helped! :)
Posted on Oct 28, 2010
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
My new case won't close correctly as if too small. I got from Amazon and was informed it fit iphone 5s. Is this wrong or what can I do. I watched all the videos and retried several times to get it to fit
It is possible they sent you the wrong case. I would say call customer service. There is a number on phones that will tell them exactly what model your phone is, including any carrier specific changes, year to year differences and so on.
Jun 11, 2014 | Griffin Technology Survivor Catalyst...
I have an itrip (2009) for my iphone, but as soon as I plug the dock connector, I got a message that says that such app is not recognized for my iphone
Hello Hinost,
The Griffin iTrip is a device that is compatible with Apple's iPod and its main function is to allow a user to listen to their iPod in their car. The device sends data through radio signals and it assigns a radio station you want to tune.
Update your iPhone if your Griffin iTrip is not working. This has been known to fix fourth generation iPhones. Plug your iPhone into your computer and launch iTunes. Under the "Devices" tab, click the "Update" button to update your iPhone firmware. Try using the Griffin iTrip again.Perform a soft reset on your Griffin iTrip if it is not powering on. Sometimes the iPhone has problems communicating with third-party devices and can lock up or freeze the third-party device. To perform a soft reset, plug the iTrip into your iPhone and make sure the iPhone is powered on. Hold down the "Menu" and "Select" buttons on your iPhone until the Apple logo appears. Try using your iTrip again after this reset.Make sure that the iTrip is completely flush with your iPhone when it is connected to the iPhone.If your iTrip is set to a station that is close to a major broadcasting station, you may be getting interference. To change the station frequency, navigate to the iTrip playlist on your iPhone.
Jun 06, 2011 | Griffin Technology iTrip Controller
Engine over heating
I assume your Apple Aux adapter in your GMC Acadia is overheating. If so, the problem is with improper insulation or poor wiring in the center audio console. Ask your GMC technician to have a look into the insulation inside the dashboard and center audio console.
If the engine is overheating when you plug in Apple device to the Aux adapter, then it is the case of wiring fault that clashes with the engine's cooling fan circuit. Most probably some loose contacts inside the dash creating some ground or electrical disturbances.
A visit to the GMC service will fix this. Also if your GMC is still under warranty, you better do not do anything fixes on your own. Such un-authorized fixes could void the warranty and GMC can take it for granted for all future services that falls under warranty!
Mar 06, 2011 | Apple Gmc Acadia 2010 10 Direct...
My adapter came apart,can i fix it?
It should snap back together unless you broke the actual piece inside you can put a little clear tape around it to hold it together
I hope this helped
Chris Thrash
Dont forget to vote on the service
Jan 10, 2011 | NetGear Wireless-G USB Adapter...
How do I take an iTrip apart?
Cut around the seam with a sharp xacto knife. It will open.
the crystal had come loose. I glued and sildered it back on. I'm back in usiness.
Jan 05, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Ipod 4th gen "charging not supported"
It does that to my iPhone; if I want to charge I have to use a separate cable and run the audio into the aux. Defeats the whole purpose of a dock if you ask me, but I guess they never anticipated what they'd have to do to charge the new iPhone batteries back when they designed the pre-G3-phone docks.
May 25, 2009 | Buck Klipsch iGroove Docking Station,...
AC power adapter
17v 2300ma switching power supply.
Mar 30, 2009 | Griffin Technology Amplifi Speaker System...
51 people viewed this question
Top Griffin Technology Audio Players & Recorders Experts
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
