Question about Corel AE CorelDRAW Graphics Suite 12 for PC
Can't open Coreldraw 12 file
Designed in Coreldraw 12 and after saving many times, got the message Temp drive or output drive may be full. Couldn't save to another file name and couldn't even copy to another. Or import the file to blank document. Searched the internet for patches and installed 3. I finally uninstalled and reinstalled the program. Tried to open the same file, but now I'm only getting The Application Recovery manager wizard. Other files that I've opened and tried to print, change the Colour management automatically.
Can someone please help!!
    Champion:
  • 404 Answers
In this case I would advise you following software
http://www.coreldraw.repairtoolbox.com which must assist you to solve problem out
Posted on Jul 23, 2012
Convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Posted on Feb 26, 2009
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
Hi my problem is: File Copy Error. Temp Driwe may be full. Would you help me?
Increase the page file size to double which can be done from computer properties(system) -- advanced tab, open perfomance settings -- advanced and in virtual memory assign a higher value for each partition. Restart computer for them to take effect
May 03, 2011 | Corel AE CorelDRAW Graphics Suite 12 for...
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
When i try to save a coreldraw problem a message appears file copy error: temp or output drive may be full what is the solution
Is your computer's "C:" drive getting full?
Are you trying to save to a file on a USB memory-stick? Is that stick getting full?
Jul 03, 2010 | Corel AE CorelDRAW Graphics Suite 12 for...
I can't open my corel draw file. When I open closed corel Draw Application
Set CORAL as a default program for your coral draw files because many specific files can only be opened by the application that created them.
Apr 24, 2010 | Corel AE CorelDRAW Graphics Suite 12 for...
I need to open a coreldraw 14 document for editing using coreldraw 12.
save your file in corel 12 format using corel 14 then open it on corel 12
Aug 31, 2009 | CorelDRAW Graphics Suite 12...
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Mar 18, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Corel AE CorelDRAW Graphics Suite 12 for PC Logo
1,227 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
