Question about Gestetner DSm615 Digital Imaging System
Error SC541 ON NRG MP 1600L
I was servicing my mp 1600l and on restarting I get an error code sc541 prompting me to restart and the process repeats. kindly advice..
  • Anonymous Mar 15, 2014
    ERROR CODE SC541
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
Posted on Feb 26, 2009
I have the photocopier name Mp 1600l and this machine is unable to load tonner stil tonner is in so what can i do please help me
Posted on Jul 03, 2011
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
Error SC 55C2
Press clear (yellow button) followed by 1, 0, 7 then hold down the stop (red/orange button) till it enters service mode.
Press on 'Copy SP' then key in '5810' and press '#' and then press on 'excute' to reset the service code.
Then just turn the machine off then on.
If SC542 re-occurs the fuser's thermistor will need a inspection.
Sep 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
I am having a problem with the ricoh aficio mp 1600L printer. It shows message"Follow instrctns in the right cover to remove". We have checked everywhere there is not paper jam. We are very...
ok mate. when you open the right cover, there is a registration roller on the side. the registration roller is black one. it is visible from the side. rotate that roller and the paper should come up. rotate that roller with hand.there is a small piece of paper stuck below that registration roller which is not visible.
Nov 26, 2010 | Ricoh Aficio MP 1600L Black and White...
Error code sc320
sc code 320 laser unit faulty polygon motor try lubricate bushing if still codeing out replace polygon
motor
Nov 11, 2010 | Ricoh Aficio MP 1600L Black and White...
Getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Mar 24, 2009 | Office Equipment & Supplies
Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Nov 07, 2008 | Ricoh Aficio 250 Copier
674 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
