Question about Abit KR7A-133R Motherboard
Abit kr7a-133r morherboard will not post At first, it would not post every now and then. I would need to turn off and on 2 or 3 times,and then it would run fine. after a couple of months it got worse, I would need to turn off and on every time. now it will not post at all. I replaced: the power supply, ddr memory, all cards, and hard drive.
  • frank215m Feb 28, 2009
    it turns out the motherboard was bad. i found out abit had a problem with some capacitors around the time this board was made. i took a real close look at the board and found two caps that had a dome. i replaced them, and it worked!
I take it you have the same type of memory[matched in pairs]. I had an asus board that did the same thing. I started the way most builders do when they bench test, I sarted with just 1 memory stick, l [left 1 rom in] and removed everything I could. With the Dell that started to act up I cleared the CMOS over night with the jumper in the clear setting. I was able to get the Dell to work, I ended up selling the Asus board and the guy who bought it said he cleared CMOS and replaced the battery and it fired right up. My first Abit board[NF7-S] came with no manual or drivers disc. It's used but one thing I can say is Abit really didn't look like it's site was much help. I am just about to test it. It does sound like a device problem. You can go online, if you updated your BIOS it may cause problems but I'd also look at the updated BIOS to see if there is a update with this problem listed. One last thing, if you have extra cables try them to see if it is the hdd cable, thats happened to me also.
Posted on Feb 28, 2009
  • valdan1 Feb 28, 2009
    Yeah I didn't address that, I have a board with capasitors so it's only a matter of time.
Can 40inch morherboard work on kdl46ex520?
NO. Both are different. If you wish to get some details; visit the site linked here. Pull up older posts.
May 26, 2017 | Televison & Video
Nv7 133r motherboard will not boot unless switched off and disconnected from mains for several hours. will only give single longer than normal beep, no video, beeps every 5 seconds
If you have multiple RAM sticks on your board, try to remove some of them and interchange, to rule out a faulty memory.
If you have an on board video card, remove any video extension cards and connect your monitor to the on board video card to rule out that as the problem maker.
If you have any other extension cards, remove them as well.
If all of that does not help, then there is either a problem with the processor or the motherboard itself, that is probably not possible to fix.
One more think I could think of is a faulty power supply. If you can get another one, try it with that.
Good luck
Hope this helps.
May 10, 2011 | Abit NV7-133R Motherboard
Have an abit bd711. when I start up the computer i sometimes get an alarm tone, and other times I do not. Not sure what it means.
You're Abit BD7II-RAID MB has many bios settings that could bring about the sound you are hearing.
See page 3-23 in you're manual. (Resume by Alarm)
Most of the settings on page 3-23 are used for power savings. Also see page 2-10 section (13). U27: POST Code Display. When you hear the alarm tone check the MB's display U27 for it's code.
I'll post a site where you can download a small program called Speccy that can monitor the temps in you're system; http://www.piriform.com/speccy/download
This can help if there is a heat problem with a device within you're system. At this time I don't feel you have a CPU problem.
Mike
Jun 04, 2010 | Abit BD7II-RAID Motherboard
WHEN BOOTING IT ALways stops with notice "Checksum Error"
replace the cmos battery into new one that is specified the exact volt..hope this helpful...
Oct 25, 2009 | Abit KR7A-133R Motherboard
My monter is not't comeing on
remove the signal cord off from your pc back panel....then powr on again the monitor after power off the monitor..
regards
Mar 14, 2009 | Abit KR7A-133R Motherboard
Need to find thew manual online so i can view specs
email me and I'll send you pdf copy markkneen@bluebottle.com
Dec 10, 2008 | Abit KR7A-RAID Motherboard
Doro 133R phone - answering machine not working
a bit late for this persons problem, but if anyone needs a manual here's the doro site - just type in the model number and you will be able to download the pdf.... http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Jan 19, 2008 | Doro 830R Cordless Phone
ABIT-KR7A Motherboard
Your manual here: http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&model=86
Bios & Drivers Download:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=4&category=5&subcategory=258&model=86&product_name=KR7A-133R
Go to page 7 of your manual. The pin layout is shown here. The manual states that these can be used at the back of the Pc but can also be used at the front of the Pc. For understanding the wires click this link: http://www.directron.com/installusb.html
Scroll down till you see in bold lettering (Understanding the wires). A picture is worth more than typed words. Enjoy!
please vote...
Dec 20, 2007 | Mercury P4VM800M7 Motherboard
Upgrading CPU
Socket A (also known as Socket 462) is the CPU socket
Best I can tell you should be able to get away with it.
http://www2.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KR7A-133R&fMTYPE=Socket%20A&pPRODINFO=Specifications&fSEARCHTEXT=KR7A-133R
Dec 18, 2007 | Abit KR7A-133R Motherboard
Abit KR7A-133R Motherboard Logo
171 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
