Question about Compaq Computers & Internet
Laptop not turning on
My hp nc6320 laptop is not comingon.The LED on the power button is not turning off when i press the power button
    Problem Solver:
  • 17 Answers
Unplug it, remove the battery, count to ten, put the battery back in, plug it back in, and try booting again.
Is there a pin-hole on the bottom of your PC that says "reset" by it?
Has your PC been dropped or anything that may have caused physical damage?
Posted on Feb 26, 2009
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Power failer
You need to check the voltage on the power adapter. If it checks out, you will need to call HP because this is an issue that is typically caused by power surge and motherboard replacement is usually the solution.
Jul 15, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
No power when i press button...led fashes 8 times
remove and, reseat your memory if that doesn't help try disconecting your dvd drive hard drive(s) one at a time and, retest
May 24, 2009 | HP Computers & Internet
Adjusting the brightness!!
Hi Stacie,
press and hold the "blue" "fn" button (buttom left, second from left), as you press the F10 button and again untill you have the brightness you want.  But be avare, you use more power this way, whitch will result in shorter battery time.
Regards /Teis
Jan 14, 2009 | HP Compaq nc6320 Notebook
Blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Dec 24, 2008 | HP Compaq nc6320 Notebook
HP nc6320 laptop power loss
Ok... As i understand the issue there is too much flea power in the notebook that's the reason why it doesnot power up....Perform a Hard Reset...Hard Reset can be done by unplugging the A/C Adapter pin from the notebook and then removing the battery and then pressing the power button for 30secs without the battery and the A/C Adapter Pin connected to the notebook... This should reslove it incase it does not please conatact me and i will surely help you out with the issue
Jul 03, 2008 | HP Compaq nc6320 Notebook
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
Compaq - will not turn on - plugged in?
Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
Good Luck
Mar 01, 2008 | HP Compaq nc6320 Notebook
Computers & Internet Logo
199 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
