Question about Bosch 1274DVS 3" x 21" Belt Sander
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
When I pull the switch, the motor won't start. Sometimes, with the switch on and shaking it it will start to run. I replaced the brushes, but the old ones did't look too worn. Once it starts, it will run until I let of the switch, which seems to "click" and work OK. Sometimes, with rupeated triggering of the switch alone, it will start.
  • 134 Answers
Hi
Definately sounds like bad switch or contact to the switch
Posted on Feb 26, 2009
I replaced the switch the cord and checked the brushes everything looks fine but it won,t work. Help
Interesting. I looked at the following URL to see if there was any safety device that might prevent it from working and I see none:
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1274DVS
If there is nothing happening when you pull the trigger, the only thing you can do is trace the wiring from the power cord through the trigger and to the motor contacts, as shown in the aforementioned URL diagrams. I assume the motor has not seized up on you since you did change the brushes. Not to sound foolish, but did you try changing the outlet you plugged the saw into? In some of the higher end equipment there is an inline fuse that is part of the AC plug assembly. Any chance that is part of the new cord? Blown or missing in-line fuses?
Please keep me informed of your progress as I find this quite interesting. Paul
Sep 18, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
PBS 7 AE belt won't turn and dust won't collecr
I had the same problem. On mine it was because the drive belt had worn out. This is under the black cover on the side. You have to remove three torx screws to remove the cover.
Jun 05, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Beltsander
whats the problem ?belt comes off?
I have a 1274dvs sander and it will not work .I use it all the time in my line of work. I think it is the switch but I dont have way to check the switch can you help.
Unfortunatly without a way to check the switch (multimeter) you will have to take it to a repair depot. Got to Boschtools.com and look under "find a service center".
Jan 05, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Dust bag won't collect
Try blowing through the little **** that collects sawdust (inside back by belt) with a compressed air nozzle, with the bag off, and squeeze the trigger and let the motor run a little. Blow out the insides as well as you can, including the air intakes for the cooling of the motor, and it should work fine again.
You can also blow out the bag to clean the pore in the fabric.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Drive pulley removal
ZGAZER
here is a parts breakdown. in center of picture is name of website where you can get a download. I cannot figure out if you are removing # 831 or 835 pulley. Either way its righty loosey on nut and you will have to hold opposite end to loosen.
Mar 08, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Toothed belt bosch 1274 dvs
If I am correct, when holding the tool in the normal operating position there should be an oblong cover on teh left hand side nea the back of the tool. It should be held on with a screw. remove this cover and you can access the belt . MAKE SURE THE TOOL IS UNPLUGGED. the belt should pull off/push on with a bit of force. Turning the pulleys as you put it on will help it go on evenly. If it is too stiff, put the belt in some boiling water for a minute or two to soften it up a bit.
Nov 03, 2008 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 1274DVS 3" x 21" Belt Sander Logo
328 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
