Question about Intel S5000XVN Motherboard
How much more memory cah I put in thei computer?
I have a Compaq presario pc model 5405 I upgraded the 128mb of ram that was originally in the pc to 256 Mb. Can I add more ram and if so how much?
In the instuction section of upgrading the components hand book it stated "that there are several different types of memory modules and that one should install the same type of memory currently in the computer.' I was instucted to go to this web site compaq.com/athome/memory, But I was not able to view that page
I get often a message that the memory is low and that some application will not be able to access. I don't understand the concept of the memory. My daughter wanted to speed up my pc, so she bought 1000mb ram just to find out that it didnot work. The satement that I mention about the ram previously dose it mean that 128 mb more was the limit of the memory upgrade?
  • 203 Answers
If you have that INTEL S5000XVN Motherboard in your pc. You need to buy PC2-4300 or PC2-5300ram. Intel say it can handle up to 32gb of ram. As it has 8 slots for ram i would say that could be possible but very very expensive. 1gb a slot would more than enough.
Posted on Feb 26, 2009
  • sean sutton
    sean sutton Feb 26, 2009
    1gb is 1024mb
  • sean sutton
    get rid of the 128mb sticks
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I got this Presario 700 from a friend. it has a
Compaq Presario 700 Memory
Maximum Memory 384MB
Memory Slots 1 (1 bank of 1)
non-removable base memory 128MB
Machine name: Compaq Presario 700
CPU options: AMD Mobile Duron (900MHz)
Chipset: VIA ProSavage KN133
HD Bus: Ultra ATA-66
Front Side Bus options:
Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
Jul 02, 2010 | Compaq Presario 700 470024-192 Notebook
Need to upgrade RAM
hi..ya you can upgrade the ram in your compaq
presario 5000.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Compaq Presario 5000 PC Desktop
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Not Enough Memory
Actually, according to www.crucial.com, the maximum amount you can have is 384mb, with 128mb in each slot.
The info can be seen here: http://crucial.com/store/listparts.aspx?model=Presario%205150
Mar 23, 2009 | Compaq Presario 5000 PC Desktop
Memory Upgrade
Not knowing what model of computer you are talking about, I'd suggest you try various combination's with your memory modules as some computers are picky and accept certain size memory chips in certain slots only.
Furthermore, it could be there is a bad connection on the sockets or if you have not been ESD safe, you could have zapped the memory chips and or the main board.
Jan 10, 2009 | Computers & Internet
Upgrade of Ram on Dell 8100
There are 2 possibilities here - either the slot is not working or the RAM itself.
First install the working 128MB RAM in both memory slots one after the other and ensure that both the slots are in good shape.
Next, install the other 128MB RAM in one slot and check if this is working good.
Your laptop can support a maximum memory of 512MB. If you looking for an upgrade, please call Dell Support. Even though it's little expensive and shipping takes a week, you can get a free after sales service and peace of mind. Moreover you get proper guidance from the experts.
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
Intel S5000XVN Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
