Question about Toshiba Satellite M35-S456 Notebook
Toshiba m35-s456 , cant turned on
The ac-dc icon is flashing but it cant turn on even it is being charged.. what should i do?
  • Seabee Tim May 11, 2010
    What happens when you try to turn it on?
  • 65 Answers
Your model of Toshiba Satellite is well known for the power plug to go bad. the pin in the back breaks the solder on the system board. Toshiba actually got sued over the issue and they used to fix this for free, the bad news is that they don't anymore.
To check if this is the case on the back of your laptop where you plug your ac adapter see if the pin will wigle with a screw driver or something. If it does then this is the problem.
The good news is that you probably can take it to a computer repair shop or a toshiba repair center to get it fixed.
If you want toshiba customer supports phone number it is 1-800-457-7777
Posted on Mar 21, 2009
Computer doesn't completely boot-up. Little history, needed a new ac adapter and bought a 3rd party/universal adapter (from 2 different vendors) and either adapter worked. Did get power to the computer but...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 08, 2010 | Toshiba Satellite M35-S456 Notebook
The fan in my Toshiba Satellite M35-S456 not working
what is not working the fan or laptop?
when it stopped working the first time it is possible the laptop overheated and fried the cpu or motherboard. check the mother board and cpu for any physical marks where overheating has occured .
Aug 02, 2010 | Toshiba Satellite M35-S456 Notebook
i need software keygen challenge code for eset password toshiba m35-s456
Oct 03, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba m35-s456 no power
To test if the adapter is faulty check it with a multimeter.
Test the output voltage on the connector that plugs into the laptop. The voltage should be 19 volts (the voltage is printed on the label on the adapter) or slightly higher because the is no electrical load on the adapter.
If there is no voltage or if the voltage fluctuates when you flex the power connector, then the adapter is faulty.
If the adapter is OK, then plug it into the laptop and the jiggle the connector a observe the charging LED light and if it flickers the fault is the power connector on the laptop. This can be repaired, it needs to be resoldered or replaced.
Jan 24, 2009 | Toshiba Satellite M35-S456 Notebook
I need the video drivers for my laptop m35-S456
PCs all use drivers for the various components they are designed to run or installed as an upgrade etc. Drivers are often updated during the useful life of the PC or device that is using the driver, so the best source is the manufacturer of the PC or the device itself. In your case Toshiba is going to be the best bet, even if you have your original restore disks the drivers contained on them may be outdated, or have issues the newer drivers were developed to fix. I have worked on a few Toshiba laptops including the M35 series, the drivers are available through the support link on their site, and with the full model # you should have no problem getting the correct one for your unit
Dec 03, 2008 | Toshiba Satellite M35-S456 Notebook
Toshiba Satellite M35-S456 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
