Question about Toshiba Satellite 1805-S274 Notebook
Toshiba satellite What can i do to my laptop to make it faster?
  • 530 Answers
Hi im josh in cebu phils. may i help you? Friend to make your laptop run faster you need to upgrade the hardware such as video card use 512 gb or higher. the memory 2gb or higher, the hardisk 120gb or higher hardisk space makes the software run faster. and lastly the processor to be contented. remember in upgrading the bigger and the higher the better it works. thats all good luck hope i helped you.
Posted on Feb 26, 2009
    Problem Solver:
  • 17 Answers
#1 answer; add RAM. What's your system specs?
  • Seabee Tim Feb 26, 2009
    When you start getting into "upgrade processor", that's starting to borderline on "upgrade PC". Not saying that Josh is wrong, but if you upgrade everything in his list, you could probably get a faster PC at a comparable price, especially if you have these upgrades done professionally. I still say #1 answer is upgrade RAM, I agree with minimum 2gb. Adding RAM is going to give you immediate results, and it's an easy install you can do yourself. Lack of RAM is the most common problem with slow computers.
    What are your system specs, ie, how much RAM do you have, what is your processor and processor speed, how big is your hard drive, and what is your hard drive RPM? What do you use your PC for, ie, what runs slow that you want to be faster?
    The "hardisk" isn't going to make as much of a difference as RAM. For example, if you're only using 25% of an 80 gig hard drive, upgrading to a 200 gig hard drive isn't going to make any noticable difference. The hard drive is the computer's long term memory, it's what stores information for use. RAM (random access memory) is the PC's short term memory, the memory the PC uses to function and operate the applications stored in the HD. If you have an abundance of RAM you can function more processes faster. If your computer has an open RAM slot (which it probably does if you've never upgraded your RAM) you can add RAM to it really easy. The thing is, it's best to match your current RAM card, rather than excede it. For example, if your computer has 1 gig of RAM, you're better off adding another 1 gig RAM card, rather than adding a 2 gig RAM card. That's difficult to explain, but the gist of it is, 2 RAM cards of equal size will function together smoothly.
    There's a door on the bottom of your PC, it probably says "RAM" on it, it probably has a screw in it. Shut down your PC, remove the screw and open the door. If there's an empty slot there, which I'm betting there is, it's available for more RAM. Before you shut down your PC, go to your Control Panel and open "System" ("Classic View"). There you can see how much Memory (RAM) you currently have installed. Match that in your vacant RAM slot to double your RAM, and you will have a faster PC.
Toshiba Satellite A200-28s battery options besides stock Fujitsu
Any SATA drive will fit up to the size limitations of your motherboard. A 1Gb is about the norm now. WD, Samsung, Hitachi etc all about the same.
A 7200 speed will give you a slightly faster seek and write time or go for an SSD drive. All are compatible if SATA 2.5" format.
Oct 03, 2017 | Computers & Internet
"Your usb composite device could run faster it it
there are several USB ports on your computer and one is the high speed one - try using different sockets.
Mar 10, 2011 | Toshiba Satellite P105-S6197 Laptop
Processor upgrade in a toshiba satellite m35x-s109
A Pentium M 1.7 (SL7EP) works great and runs cooler.
May 01, 2010 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite a70-s256 fan issues
Instead, turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", to remove all the dust that has accumulated inside your computer.
The dust has been acting as "insulation", forcing the fans to run faster, and with more noise.
Cooler computer -> quieter computer.
Jan 16, 2010 | Toshiba Satellite A70-S256 PC Notebook
Which wireless card for Toshiba Satellite 1905-S301??
Lots of incompatibilities and covering pin 13 does NOT solve the problem with this series laptops. Get the MPC13A-20/R 802.11b card - it works wonderfully well, even though it's only a 'b' card.
Dec 08, 2009 | Toshiba Satellite 1905-S301 Notebook
What is required to upgrade my Toshiba A20, to a new faster machine, without spending big $$. Or upgrading to a new machine. I have already upgraded the ram, to its max..!
upgrading your PC or laptop means updating every software installed in your PC or laptop except those installed by you...
please vote for me...im sure this will solve your problem...
Jul 01, 2009 | Toshiba Satellite A20 Satellite A25 Series...
How can I make my laptop works faster?
You don't say what OS, assuming XP
I'd try the following:
Run windows disk cleanup and defrag
Run a cleanup program like ccleaner
Run a registry cleaner like regcure or eusing
If that doesn't help add more memory (you should have at least 1GB and preferably 2) or switch to Linux :-)
Jun 17, 2009 | Toshiba Satellite Pro L300 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
What type of router to buy
I would by the "N" router. It is faster and is the new emerging technology.
Jan 24, 2009 | Toshiba Satellite A205-S5804 Notebook
Toshiba satellite 2805-S301 laptop wireless card
Not wireless ready - as none of the 2805's were ever pre-wired with wireless card antennas. You can install a PCMCIA wireless card, or use a USB wireless adapter. Either one will work - the PCMCIA cards will be faster.
Dec 08, 2008 | Toshiba Satellite 2805-S301 Notebook
Toshiba Satellite 1805-S274 Notebook Logo
204 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
