Question about Panasonic Home Theater System System
We have been given a panasonic quintrix tv with surround sound speakers and a sub woofer. What we need is the cable that plugs in to the sub woofer and then into tv - this is missing. The connection is a lot smaller than a scart lead pin socket - and cannot seem to find one. I have been told by Maplins that it will be a manufacturer part. Do you know where I can get hold of one? - if you understand this query, that is - sorry not very technical!! Thanks
  • 203 Answers
You can get any panasonic spare parts direct from them.
http://shop.panasonic.co.uk/page/home
Posted on Feb 26, 2009
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board....
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Aug 08, 2017 | Logitech X-530 5.1 Surround Sound...
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
Surround sound system is not producing sound through the subwoofe
Several things could cause this, to make sure the sub woofer is working at all disconnect the cable from the back of the receiver. You should hear some sort of output from the subwoofer when you handle the plug. IF so replace the plud and go into your settings menu (press the A and B button at the same time) and go through the speaker set up. It may be that the receiver has not retained the memory that there is a sub woofer connected.
I hope this helps.
Feb 24, 2009 | Panasonic SA-HE90 Receiver
Trying to get surround sound speakers to work with TV
They come with 3 x 3.5mm stereo to 2 x RCA phono cables, so are obviously meant for plugging in to the back of a PC with 6ch output.
BTW - they're ****.
I should've known for £29....
Jan 06, 2009 | Audio Players & Recorders
Lcd speakers
I suggest to unplug surround and sub woofer so you will get sound from front speakers only.
Dec 12, 2008 | LG 42LG50 42 in. LCD HDTV
Surround speakers, how to get them to work AIWA Z-1800
Make sure you have each component linked to your system and thew sound for each input set to prologic to get surround sound.
Hope this helps.
CABLE GUY.
Nov 15, 2008 | Audio Players & Recorders
Hardly used this amplifier in conjunction with a Panasonic TV Quintrix
just about any decent amp with surround sound capabilities will solve your problems there !!! all you need is male - male phono jacks and your away
Sep 11, 2008 | Audio Players & Recorders
The Surround Sound sub-woofer doesn't play bass likes it's supposed to, but the bass plays out of the of the left speaker. What's the problem and how should i solve the problem?
check the setting of your sub and confirm that it is on-check cable of sub and confirm it is connected firmly.-disconnect power cord and reconnect it again.
Jun 26, 2008 | Panasonic Audio Players & Recorders
Panasonic Home Theater System System Logo
177 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
