Question about Dell PowerEdge 1800 Server
Do i loss my old data if i make new array on the raid if yes how can i recover that data
  • sajid487 Mar 01, 2009
    thnks alot but if it is raid 5 then
    Novelist:
  • 148 Answers
there are many types of raid, which type of raid you are talking of, if you are talking of raid which use mirroring of data, in that case if one drive is lost there is no data loss, when you add a new drive for that bad drive, and then the data on the working drive will be mirrored on the new drive added,
Further Queries are welcome
Posted on Feb 26, 2009
How do I rebuild broken RAID 1?
If Raid is broken then logical drive will fail & will result in data loss.
enter into Smart Array Controller bios by pressing F8 & Recreate Raid 1 by selecting two working drives.
Nov 19, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
3 of 6 drives on Pegasus R6 (12TB) Array show offline
If this is a RAID 5 and the data is of any importance I would definitely suggest consulting an expert. RAID can be tricky. Read some precautions here :Best Way to Recover Failed RAID 5 Array Quickly and Affordably Proceed with caution, I cannot tell you how many times failed attempts have come into our office making things next to impossible to actually recover the data.
Apr 13, 2014 | Promise Pegasus R6 12TB RAID System...
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Mar 07, 2014 | Dell Dimension Computers & Internet
Operating system corrupted how to recover the data
RAID is only to protect data in case of hard drive failure. Data is only recoverable from backup.
However, if you have a separate arrays for the OS and data. Meaning two arrays, you can swap arrays onto an identical server with same array configuration. Drive positions (bay /slot) are critical.
Oct 01, 2012 | IBM x3400 Server
How do I recover data from raid drive hard drivesrunning XP Pro ?
The failure of just one drive will result in all data in an array being lost.
What you really need to decide is whether continue with RAID (I DO NOT RECOMMEND THIS OPTION) or go with a more conventional setup where you can dramatically the reduce the risk of data loss and be better prepared if a drive happens to die. Did you have a backup?
Nov 28, 2009 | Computers & Internet
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
RAID 0 Array disappeared after reboot
I would try the hard drive on another sata controller/port to verify that the bad drive is in fact bad. If it is really bad, then no there is nothing you can do but replace the drive and recreate the array (losing all data!).
You can not 'recover' a failed RAID-0 array because there is no parity or mirror data on an extra disk like there is with the other RAID modes. This is why people recommend against using RAID-0 for important data (unless you take frequent backups): RAID-0 actually increases your likelihood of losing your data. Statistically speaking, you are multiply the failure rates of each individual drive together.
Dec 22, 2007 | Promise FastTrak S150 TX2Plus Serial ATA...
Raid w/ hard drive defunct
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Sep 23, 2007 | IBM xSeries 226 Server
Raid 5 crashed
Hi Chris,
How many drives are part of the array and what type are they? Are the drives making any unusual sounds like clicking or screeching? If not, then you should be able to recover the data. If the drives are making clicking sounds, you will probably need a professional data recovery service that specializes in Raid 5 data recovery to help you.
If the controller shows that only 1 drive is bad, you should be able to rebuild it by replacing that drive. If the controller shows all the drives are bad, then it is most likely a problem with the Raid 5 controller itself. In this case, you could try putting the drives in a working version of the same enclosure/controller.
Check the obvious also, like loose connections to the drives. Whatever you do, dont force a rebuild as this will probably result in permanent data loss.
Wesley Gill
Gillware Inc.
Raid Recovery Info
Aug 28, 2007 | D-Link DNS 6040M (DNS-6040M) Hard Drive...
Dell PowerEdge 1800 Server Logo
181 people viewed this question
Alun Cox
