Question about IBM ThinkPad T22 2647 Notebook
T22 boot fine, runs for four or five minutes and then dies.
This happen regardless of power source (batteries or powersupply) funny little circle z light stays on, screen goes black, harddrive can be heard screaching to a halt, and does not accept any key entries - machine then refuses to fully turn off. What a ****!!!!
After repeated attempt does not always boot before dieing
  • 2 more comments
  • w_bryant232 Feb 26, 2009
    There are a series of little lites on the top of the keyboard, not
    really sure what they are saposed to mean. I believe the circle z one
    means the machine is in rest/sleep mode.
    No I do not have a system recovery disk (bummer) never used one.
    Op sys is XP pro sp3.
    This does not seem to be a software issue, system boots and runs fine. till it seems to lose power.
    I'm thinking power management or heat? Seem to run longest when left off for awhile before tring to reboot again.
    Yes
    this problem occured when I was dragging my machine around one day (so
    maybe a bump or two here and there). But no sledge hammer - not yet!
  • Deddly May 11, 2010
    If you go into the BIOS (press F1 when you see the Thinkpad Splash screen on boot up) and leave it, how long does it last for before dying? If it doesn't die when in BIOS then it would be a software problem.
  • Seabee Tim May 11, 2010
    Although you're probably right, it's probably physical, it could still be a software issue. I had a computer that'd over heat on me all the time, I used to stick it in the freezer for a half hour or so before booting up--until I finally got a new one--but that one would just turn off, no shut down, no "goodbyes", just off. I guess it wouldn't help to run a recovery if you can't keep it on long enough to...run a recovery. Have you tried booting in safe mode? If you can boot it in safe mode and the problem doesn't happen, then it's a software issue, probably driver conflicts or corruption. If you installed any new software recently you could try a system restore. Laptops are fairly durable these days but even the best of them can get bumped the wrong way...you may need to shell out $50 or so and have it professionally diagnosed. Could be your clocking or something simple in your power settings. In-other-words, I really don't know, and I wish I could be of more help...
    You lost me at "circle z light". What is your operating system? Is there any chance of physical damage (as your computer been dropped, have you hit it with a sledge hammer?)
    At first glance I recommend a full system recovery. Do you have recovery discs?
    Problem Solver:
  • 6 Answers
The "circle z" is the power indicator light. The fact that this stays on tells that this is not an overheating problem, which is common, since in that case the power and light would go off Do you all know a blast of canned air or whatever source can clean out most dust and lint accumulations that cause this problem? Just blow in where the hot air comes out. It sounds like it could be a hard drive probem, recently I have had more failures of fairly new ones. You might try booting it in safe mode, hit (F8) while starting to boot, and see if you have the same trouble, this would eliminate a driver problem as the source if it didn't happen in safe mode
Posted on Mar 21, 2009
Acer 5733 will not turn on
No solution, mine does the same exact thing but blinks orange five times. I got an error message that said click to fix it. I did it and the computer tried to reset itself but simply died. With brick cord out...nothing happens. Same with battery same with power cord in. The battery was fine. It may have died during a forced windows update. I hope someone comes along otherwise it's "buy a mobo" and buy a battery and so on....
Sep 06, 2012 | Acer Aspire 5733Z-4633
My mower is four or five years old and has done well, but now when it is used it runs great for about fifteen minutes and then sputters and dies. When it does this it will not restart until it cools
The oil level is low. when the oil drains from the engine it fills the base to the level of the sensor. When it runs it takes a little time for the oil level to drop below the sensor..........Hope this helps.
May 20, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Yamaha dt125 R 2004 I've just had the engine rebuilt, re-bore with new crank and piston etc. I've just had my bike out for a run about after about a month without being started. It started on...
Your description sounds like a fuel related issue. Try connecting an external fuel source and test again. there is a screen in the fuel tank that gets plugged, and so does the filter... If external source does not help, look into the carb(s).
Carry an extra spark plug, and when failure happens, pull the plug wire and hook it to the extra plug, and ground the plug against the engine.....does it spark? If it has a good spark, the ignition is not likely your issue. If spark is very poor, ignition heat issues may need to be addressed.
Mar 22, 2011 | 2004 Yamaha DT 125 R
2002 F-150 regular cab. Idling seems like it wanted to die. While driving would rev up and down wanting to die. Finally died at a red light and had to be towed home. In the driveway it acts like a dead...
From what you describe, it sounds like your alternator died. The battery's main function is to provide power to start the vehicle. Once started, the alternator takes over and provides the main source of power to the truck, and also recharges the battery.
When the alternator stops working, the car starts to run solely off the battery. It will work for a little while, but as the battery starts to lose power, strange things will happen with the electronics. The computers and other electronics that control the vehicle are very dependent on a constant, steady flow of voltage. When that voltage dips below 11 or 10 volts, the car may start to run badly or strange things may happen with electrical system.
When there was finally not enough power to keep the car running, it shut off. Of course, once this happens, there will not be enough power left to start the truck back up.
Feb 24, 2010 | 2002 Ford F150 Regular Cab
Blinking green circle & burning odor
Check the powersupply the little black box in the middle of the power cord see if it smells ok if not then it has failed, just buy or find another powersupply with the same voltage and same or more amps than the other one and try it. if the smell is coming from the MY book itself then it's probly the Drive in whick case it needs to be replaced.
Feb 24, 2010 | Western Digital My Book Essential Edition...
I have a Gateway MP8708 lappy. While surfing the net it powered down on me. Now it does not respond to depressing the power button. It will not show that it is charging when I put the charger in.(Charger...
Take the battery out and try to boot it on AC power only, if the machine boots but can't load the operating system then the ticking sound could be and sounds like the hard drive has possibly failed.
Good luck.
Jun 29, 2009 | Gateway MP8708 Notebook
Van dies while in operation
That points to the battery.
Does it click or chatter when you turn the key to restart?
You have an apparent GROUND and POSITIVE 12v off the battery when the car IS running, but noyjhing when it dies. I love a mystery ;-)
If there is a loose connection at either terminal of the battery or the cables where they connect to the car frame, the connector lugs at the battery will arc and vaporize the metal at the weakest point of contact and all you will get is a click. Take off the battery connectors and clean the posts and insides of the connectors with sandpaper, then starting with the POS (Red +) side, push them on firmly, loosen the clamp bolts tap them several times around in a circle with a small hammer, block of wood or screwdriver handle so they seat all the way down, then tighten the bolts. If it wont go, remove the bolt, insert a flat-blade screwdriver in the **** and twist the screwdriver to expand a bit then tap some more. NOT HARD... just alot of little taps) Put the bolt back in and do the NEG (Black, -) the same way.
NOW it will start!
Mar 27, 2009 | 1996 Oldsmobile Silhouette
IBM Think pad T22 problem
Hi
Check your laptop CPU fan is running if no replace it. Problem is because of over heating....
Thanks
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Battery/Power Issue
Cant help with the "cheap bastard" part, that is for your own edifcation. Anyway, have you adjusted your laptop power/battery settings. If you have tried changing your settings to "Max Battery", and it is still doing this it is probably a hardware issue between the MB and the battery interface. Thus the second part of your message might be comming true. Sorry.
Aug 20, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
164 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
