Question about Acer Aspire 5610 Notebook
How do I get the back off My Acer 5620 laptop. The CPU fan does not seem to be spinning and it keeps shutting down. I've pulled about 30 screws out of it and the thing doesn't want to split.
  • kimgransch Mar 01, 2009
    Misinformation
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend if the cpu fan stops spinning the air inside and the processor heats up easily thats why it will shut down.you need to replace the fan of the cpu to avoid further problems to occur. in removing the screw it will not be disassembled easily because it has a safety bracket lock.to make it open you need to look frot he weak spots and you split that side until it opens the whole unit. thats all good luck hope i helped you.
Posted on Feb 26, 2009
My acer notebook 1 keep shut down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 25, 2012 | Acer Aspire One PC Notebook
My lap top keeps shutting off
Aug 23, 2012 | Acer Aspire 7720 Notebook
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
Acer Aspire 4930 heats up very quickly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
Laptop won't boot turns on then off after about
Your Laptop seems to be full of dust - Maybe your CPU Heat sink FAN cannot turn because if this THUS causing your laptop to heat up and shut down again to prevent your CPU from receiving damage due to high temperature.
Close your laptop lid, then put the unit on its backlcd. Make sure you disconnect the Battery and the A/C Power chord. With the emty battery slot is facing you, take note of the screw that is facing you to the right on the bottom cover. There might be others like this in the same area. The cover that you need to remove is of rectangular shape, and the largest cover.
When you have removed it you should see the CPU Heat sink and a FAN. This is the part where you blow the unit out at that spot with compressed air so that the dirt will no longer block the heat from venting away from the laptop mainboard/cpu.Please check if the CPU FAN is still turning licenly. If it doesn't turn or very difficult - replace .
[ADVANCED]
Then, remove the 3 screws from the CPU heat sink and thereby remove the HEAT sink completely. Remove the CPU Heat sink FAN and clean it as nessesary. Use a small flat to switch the CPU from closed to open and remove it. Then clean it with a cloth and ethanol - make sure you remove all dirt and old heat sink paste on top if it. make sure you do not touch the bottom of the CPU and handle the pins carefully.
When you are done, place the CPU back and reaaply a eyedrop of fresh heatsink paste onto the CPU, lock the CPU switch again. Then clean the backside of the CPU heat sink where it rests on the CPU. When you are done with that, place the CPU heat sink back onto the CPU then screw the 3 screws back onto the CPU heat sink and onto the mainboard. Keep the sequence in mind. Reconnect the CPU Heat sink FAN to power on the mainboard with the cable then place the cover back onto it. Tighten all screws again and reconnect battery and A/C Power chord.
Jun 04, 2010 | Acer TravelMate 4230 Notebook
I've had my acer aspire (5315) laptop for over 2 years
Sometimes, the CPU heat sink fan might get clogged up or faulty or stop spinning entirely. Make sure that the fan can turn properly.
IF YOU CAN, open the unit when the battery is disconnected and the power is not connected, then reseat the CPU Heat sink and re-apply a eye drop heat sink thermal paste onto the CPU. Reconnect and tighten everything again properly and adhere to the sequence in turning the screws back as per their numbering on the heat-sink
If the FAN has trouble spinning, doesn't turn at all or is noisy and runs irregular please replace the fan. The fan alone should cost about a few US $.
May 16, 2010 | Acer Aspire 5315 Notebook
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Compaq Presario M2000 - Fan not running
It appears your CPU is overheating and is shutting down.
Does the fan spin at all when the laptop is switched on?
The fan could be faulty, if it does not spin freely.
To test the fan, try removing it and connect it to a 12 volt DC power supply, if the fan spins fast then it is OK and the fault is on the laptop, possibly the power supply to the fan. In this case you need professional help.
If the fan appears OK then the problem could be insufficient too old heat sink compound between the CPU and the heatsink. You will need to remove the fan and heatsink and the old compound and put some fresh heatsink compound on the CPU/heatsink and reassemble the fan/heatsink.
Dec 29, 2008 | Compaq Presario M2000 Notebook
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
Acer Aspire 5610 Notebook Logo
413 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
