Question about Hotpoint First Edition FEW12 Front Load Washer
My hotpoint wma11 sounds like its washing rocks,bearings gone?
  • Anonymous Mar 22, 2014
    is there a trap in this washing machine
  • 221 Answers
Unfortunately yes if this sound appears when the drum is spining, if when drum is still, than the pump wearing out
Posted on Jun 22, 2009
How to take out a coin from inside of hotpoint wma 11
front cover should pull off on washer to let u at filter
Mar 14, 2015 | Hotpoint WMA11 Front Load Washer
Wma11 starts to load water then goes to end program within seconds
hi try another program like spin cycle if is still the same the programmer timer control could be the fault
regards
shaun
Dec 05, 2011 | Hotpoint WMA11 Front Load Washer
My Hotpoint first edition WMA11 will not start as it does not recognise that the door is closed.
check to see if you can use a small object to simulate close door if works switch needs to be adjusted
or replaced
Jun 09, 2011 | Hotpoint WMA11 Front Load Washer
Excessively noisy when it spins. The faster the spin the noisier it gets.
Sounds like the Drum Bearings are gone they are **** on Hotpoint..Could be quite expensive depending on age...3 years old you will need a half drum complete with Bearings approx cost £80 plus labour....if more than 4 yrs old then perhaps bearing kit plus 3 hrs labour....Hotpoint give a FREE 5 yrs parts warranty however CALL CHARGE....£105 approx parts are free.....You need to ecide if you should fix or just buy a new one........
Jan 14, 2011 | Hotpoint WMA58 Front Load Washer
Hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
May 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum bearing very noisy on my hotpoint wma44 wshing machine
Sounds like the seals have gone as did the ones on mine. It need a complete new spider frame and bearing set as the front bearing had collapsed and groved the bearing spindle. Open the door and try lifting the drum to see if there is any up/down movement.
Aug 31, 2009 | Hotpoint WMA44 Front Load Washer
How to change brushes on wma11, mainly how to i get the top off?
There are two screws on the rear of the lid, one near each corner, undo these and lift the rear of the lid a little and pull back to release the front from its clips. ( but first, if I am correct in thinking the motor is underneath on these, tilt back the machine and lean it against a wall or cabinet, and look to see if it's underneath.
Jun 15, 2009 | Hotpoint WMA11 Front Load Washer
Hotpoint WMA11
If the motor is not getting power when it is called for spin. Then check the computer and the timer. Also check the balance sensor
Feb 14, 2009 | Hotpoint WMA11 Front Load Washer
Hotpoint Aquarius WF 430
Best way to check if the main drum bearings have gone is to;
  1. Remove back panel of washer
  2. Remove drive belt.
  3. Spin drum by hand from the inside of the drum, if it feels rough, or is noisy and rumbling, then the main bearings have gone.
If there is no apparent noise, then you will have to investigate further.
If I can help further, pleas let me know.
Plz rate my solution.
Thanks.
Oct 31, 2008 | Hotpoint Ultima WF865 Front Load Washer
HOTPOINT CTDOOP CONDENSER DRYER
If you can move just the drum(not the whole tub). If the drum is "loose", the bearings are gone! I really dont know how to change them on this machine, but it is usually pretty difficult.
Jan 20, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
173 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
