Question about Northgate (STAX2517C2) PC Desktop
When i plug a 2nd hard drive into the ide socket the monitor says no signal sent i had this hard drive working a while ago could it be because there is an operating system on the 2nd hard and if so how can i format it thanx
  • 1 more comment
  • Allan Kierszten Feb 26, 2009
    cheers for your help
    i was checking the disc just now and the jumpers are set to slave
    just wondering if there is any i can format the disc somehow????
  • Allan Kierszten Feb 28, 2009
    thanx for your help
    still not fixed yet but i'm keeping on trying
    i will let you know as soon as i figure it out
    the main problem i have is that the disc is out of the pc and when i try to put it back in thats when the problem starts everything is ok until i plug the blue end of the ide cable into the motherboard then the monitor switches off and says no signal
    hope this makes sense to you
    it may be a faulty ide cable,socket or i think its because the drive has an old operating system on
    i think the only i can format this drive if i was to buy a case and try plugging it in to the usb port
    unless you know anyway i can scrub this drive before i put it back in the pc
    thanks anyway
  • 203 Answers
It is more likely that if you have a system installed on it that you still have the jumpers set to MASTER. you need to change them to SLAVE.
Posted on Feb 26, 2009
  • 1 more comment
  • sean sutton
    sean sutton Feb 26, 2009
    yes you can
    Windows - Second Drive Format Steps: Format a Computer Hard Drive or Disc Drive.
    First make a Startup Disk: To create
    a Startup Disk, click the Add/Remove Programs icon in
    Windows Me/98 Control Panel. WebTechGeek.com
    1. You can start by double-clicking on the
    My Computer icon. Now click the second drive icon to select
    it.
    2. Now open the File menu and select Format.
    The format window should displays the hard disk capacity.
    3. You need to select Format type and enter
    a disk label (name). If you want to Boot up from your
    second drive, you need to check the "Copy system files"
    box.
    4. Now click Start. Windows displays a warning
    box. After you read the warning, and then click OK to
    begin formatting. Warnings: The format procedure deletes
    all files on the hard disk, This action is not reversible.
    Be sure to back up any files you want to keep. Format a Computer Hard Drive or Disc Drive. Remember
    to come back to WebTechGeek.com for more How to tips!
    You may need to use FDISK to Partition
    Your New Drive; how to in Windows
    In Windows, click Start > Programs >
    MS-DOS Prompt. Type fdisk at the DOS prompt and press
    Enter. Press Enter again to allow the hard disk to be
    formatted (later) in 32-bit FAT format,
    Now press 5 to change the current fixed disk drive and
    then press Enter. You are going to format the second drive,
    your new drive, make sure that you don't format
    the first drive (the C drive). Then press 2 (to format
    the new drive) and press Enter.
    You need to press 1 and then Enter to create a DOS partition
    on drive 2.
    Now press 1 again, and then press Enter to create a primary
    DOS partition. You want to create a primary DOS partition
    to allow this partition to become the bootable volume,
    the C: drive.
    Now press Enter to use the maximum available size of
    your new hard disk for the primary DOS partition. All
    drives less than 8GB will use 4K clusters for file storage.
    You might as well format the whole drive as one primary
    partition unless you have criteria other than optimal
    file storage space efficiency for dividing the drive.
    Now press Esc to end FDISK.
    OK reboot Windows, and your new formatted hard drive
    will be recognized as drive D:. The second primary partition
    is assigned the drive letter D: Format a Computer Hard Drive or Disc Drive.
  • sean sutton
    sean sutton Feb 28, 2009
    i put a small 4.3gb drive into my pc today and it shows in the bios but not on the system once windows has booted. my drive is corrupted. is this the same problem as yours? have you got a faulty drive? it may not be able to fix. i will look for some hard drive checking software for you. you may be able to pull it back. i will post back soon.
  • sean sutton
    an operating system on a slave drive would not be an issue because there is no boot log for dos to enter onto that drive for system information.
    are you plugging this in while the computer is running?
    have you been into bios and auto searched for new drives before boot up?
    try removing your cd player(that works) and use that ide plug and power connection to try the hard drive.
    then if the drive works you can start with the cheap parts to test first, the IDE cable being just a few pence.
    if your drive does not work or does the same error in the cd ide come back and i will run through a few more things with you.
Adding hard drive to computer
ide drive or sata drive? it is a simple job once the case is open look for the ide connector (secondary ide channel connection also located on the rear of the drive is a group of pins read the directions supplied with the drive to place the pins in correct location ) or the 2nd sata connection plug them in and plug the power lead in & re-boot windows should found the second drive.
Feb 09, 2012 | Computers & Internet
Dell monitor receives no signal after a while - tried new monitor still the same problem
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
hope this helps you
Oct 15, 2011 | Dell E153FP 15" LCD Monitor
Fitted new motherboard now can't get signal on monitor
what type of computer laptop or desktop
test all leads that attach to your hard drive including electrical extensions IDE / SATA
the leads from your ((motherboard to your hard drive)) IDE/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
hope this helps you
Oct 08, 2011 | Computers & Internet
My monitor keeps shutting off...then asking for signal...while my CPU is turned on... no idea what happen only for one thing, last 3-4 months ago, the said monitor was turning from black to green while im...
Test the PSU if the units fan is not working the power supply unit is faulty
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 20, 2011 | Computers & Internet
Need to know which is master, slave and cable select
these may vary depending on the make of your hard drive
enable cable select:I:: master or single driveI:::
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 23, 2011 | Computers & Internet
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
My desktop computer is done and I need to get the information from the hard drive. It is a Samsung Spin point Sv0813h/TGM. I bought the IDE to USB kit. How do I make it all work?
It is really easy. If your using Windows 7, plug the IDE to USB connector to your Samsung Hard drive. Then using the provided USB cable, plug in the USB cable to the Hard drive. Then plug it into an available USB port on your other PC. Window will automatically install the needed drivers for you. Then navigate to Start/Computer/Local Disk E. Assuming there is no 2nd hard drive or partitions installed. And there will lye your Samsung Drive.
Aug 30, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Newly build computer problems
i bet your power supply isnt powerful enuf for your video card.
Jan 31, 2009 | ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom...
Northgate (STAX2517C2) PC Desktop Logo
171 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
