Question about Gigabyte GA-8KNXP Motherboard
The board suddenly stopped booting up. it is a gigabyte GA-8KNXP, and occasionally it will light up the screen and start to boot, but then disappears. David Hoey
  • valerie_hoey Mar 01, 2009
    hi. David (my son) has cleaned out the processor fan, and left the battery out overnight, but it still will not boot up in the morning.
    Valerie Hoey.
Ok David
I have the same problem with my mobo but it doesen't give any beep codes.
The first thing that you can do is to check that you have properly and firmly connected the power cable to the mobo.Secondly check if you connected the additional plus12 volts 4 pin cable into the mobo.After that turn on and check if the cpu fan is spiniing and as well other external cpu fans are spinning that way you'll now it's not the PSU(simply becouse is giving power to the cpu
Second step if that doesen't help try to remove all the devices exept for the memory you put only one memory stick into difrent mem slot,also good idea is to try and reseat the cpu take it carefully out and insertit back into the socket
also make sure that you firmly atached your monitor cable and grafic card firmly into the slot
Try it .If that doesen't help check this page
http://www.computerhope.com/issues/ch000607.htm
Hope this helps
Please let me know if anything helped
Posted on Jan 07, 2010
  • 564 Answers
  • Disconnect graphic card, sound card and internal modem (if any) connected to the motherboard.
  • Disconnect all the cables in the back of your computer tower and connect only monitor,power and keyboard.
  • then turn on the computer.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Mar 01, 2009
    Sniper:
  • 113 Answers
open it up and make sure you installed all corecltly it can be tones of things.Try taking stuff out and checking if you have another GPU test it if it posts,try both memmory sticks one after another,disable onboard LAN and Sound adapters and see if it posts
Good Luck!!!
neo
  • 530 Answers
Hi im josh in cebu phils.Did you add any new hardware? Remove any unessecisary external devices, such as external hard drives, Printers, USB Memory Sticks, Joyticks, or similar items. Your beep may be what is called a beep code, in which beep codes indicate problems with certain hardware, such as the motherboard, RAM etc..or ]
If you are getting a beep or a series of beeps I would check the beep code listing. Beep codes vary by BIOS provider. The following website lists beep codes for several BIOS providers. http://www.computerhope.com/beep.htm
You've removed the drive and it booted normally. Have you reinserted the drive. Make sure the power and IDE/SATA cables are securely attached to both the motherboard and the drive. If the PC won't both with the drive installed, I would try another hard drive if you have one or can borrow one. If it boots with a different hard drive installed, then I'd say we've identified your problem as a faulty hard drive good luck hope i helped you.
Posted on Feb 26, 2009
  • 679 Answers
Check out the Processor fan.
and let me know.
  • 13,433 Answers
Hey,
Start by unplugging components from the motherbard, start by disconnecting all extra ram, leave only one module, disconnect any extra devices connected. just have the minimum, motherboard, memory, video, powersupply. Connected try starting up.
Do you hear any beeps at any point? have you tried another video card?
  • Ekse Feb 26, 2009
    Also note, if you want to continue troubleshooting with me, use the Add a comment button instead of reposting, which will get you another expert.
Stop post screen showing on boot
it is in cmos you need to go there hit the delete key on startup ok
Mar 22, 2014 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Gigabyte motherboard GA-8KNxp will not power up
If you have just installed a new mother board, refer to your manual and double check your connections for pwr switch. If this is a machine you've had for a while and it just stopped powering up then your power supply is probably broken.
Feb 23, 2009 | Gigabyte GA-8KNXP Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Gigabyte GA-8KNXP not going to POST
You can find leaky caps...
Anyways, those boards have very small inductors that look like caps and are used as pico fuses on most all peripherals and controller chips. Check that they are not blown and replace them with something from DIGIKEY or MOUSER
Also starting with the most simple, check that the power supply itself has not gone into SHOCK. unplug it from mains and TOGGLE the voltage selector switch, MAKE SURE it is back to 110 or whatever you need.
I know it sounds weird but I have resurrected MANY PC's that way.
Other then that it sounds like you are well on your way to finding the defective component on your own. just thought I would throw in the fiew things that have caught me off guard in the past.
May 01, 2008 | Gigabyte GA-8KNXP Motherboard
System will not boot
bbios updating required + check ur cmos battery too!
Nov 05, 2007 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-8KNXP wont goto POST
The Power Supply dude/dudette, Ive jst gone through the same thing and found Power supply was fried... Got it working fine now... gotta update Bios tho.
Sep 18, 2007 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP Motherboard Logo
124 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
