Question about Acer TravelMate 3260-4874 Notebook
I have a Sony Vaio and the notebook speakers are not muted now when a jack plug is inserted. all usual ways tried with no effect. Someone said it is a common driver problem. Has anyone any ideas and how it can be solved? Jack G
  • Jack Griffiths
    Jack Griffiths Feb 26, 2009
    No go I'm afraid. I've tried many things like that
  • 203 Answers
You may just need to change setting in your playback device properties to cut out the speakers when the jack is inserted.
Posted on Feb 26, 2009
  • sean sutton
    sean sutton Feb 26, 2009
    what model is your laptop?
Headphone jack doesn't work on sony vaio VGN-SZ430N
Can you confirm you're headphones work? You are getting sound through the laptop speakers as well?
Dec 24, 2012 | Sony VAIO VGN-SZ430N/B Notebook
Hey, I got a little problem here...I am using sony vaio vpcee23fx . The problem is there is a sound like buzzzing coming out from the multumedia speaker when I plug the jack in to my sony audio jack. While...
Probably, the multimedia audio jack cable has kinked and in turn gone partially bad; especially close to the audio jack head.
What you can do is take it to an electronics/phone/tablet repair shop and get the jack head replaced.
Should work fine after this.
Oct 11, 2017 | Sony VAIO VPCEE23FX/BI Notebook PC
I think I have broken my headphone jack on my sony vaio VGN-CS320J because headphones plugged into this jack do not work, unless held at a certain angle, otherwise sound continues to come from the laptop...
It might be the plug on the headphone that's bad - try it on another laptop. If it's the jack that's bad, then it will need to be taken apart and that's not easy to fix - recommend having a repair shop fix it.
Dec 24, 2010 | Sony VAIO VGN-CS320J/P Notebook
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
PCV-RX770 Sony Vaio Digital Studio PC. Usually when I unplug the speakers, the sound comes through the CPU. The speakers are not plugged in, the volume shows normal, the mute is not on. How do I turn the...
have you tried going to start then go to control panel then go to sounds and audio devices and look to see if the internal speakers are turned on. most pc's will turn them off when they see external speakers pluged in then when you unplug the speakers you have to go these steps to fix the problem.
Jun 10, 2010 | Sony VAIO PCV-J200 PC Desktop
Sony Vaio vgc rb52 no sound ... speakers work/computer sound won't work?
Hello there... Check your PC's volume. You may or someone in your household has accidentally muted it. Unmute it or increase its volume (if you can't find the audio icon in the taskbar, proceed to the control panel - it's there), it maybe too low. Hope this helps... Ai :)
Dec 03, 2009 | Sony VAIO VGC-RB52 PC Desktop
Headphone jack seemingly screwed up
What generally happens to connectors, especially exposed to air is they oxydize.
Buy a can of "Contact Cleaner" from a local Radio Shack and spray it (through the thin tube usually provided) into the jack. One quick push, dont flood it. Take the earphone jack and insert and remove it several times, wiping off excess, which sould clear contacts and it should work normally again. If not it would have to be replaced which is no easy matter requiring an experienced Technician or Factory. Sometimes it cannot be replaced without damaging the Mother Board. This however sounds like a common problem the Contact Cleaner will fox
Cheers,
Good Luck :)
Sep 04, 2009 | Sony VAIO VGN-FS640W Notebook
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
Acer TravelMate 3260-4874 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
