Question about Toshiba Satellite A135-S4527 Notebook
My computer's dvd drive doesn't work, it can play cds and it can burn disks but it can't play dvds. ...
  • Seabee Tim May 11, 2010
    in your Start menu search type "Device Manager". Open DM, and click the + next to "DVD/CD-ROM drives". Is there a next to your DVD drive? Double click your DVD drive and under the "General" tab, what does it say for "Device status"?
  • 530 Answers
Hi im josh in cebu phils.may i help you? if your dvd drive does't work with dvd inputs. try to check the following first be sure to clean your dvd drive coz dust may cover the lens inside that would make the drive wont work. 2nd if you are using different OS be sure to install dvd drive software such as power dvd etc. and lastly be sure you entered clean and clear dvd inputs. thats all hope i helped you.good luck
Posted on Feb 26, 2009
The drive does not play cds nor dvds. However, it burns both cds and dvds very well. What is wrong here? How do I fix it?
The image receiver is probably bad inside the laser lens. When the laser light emits and reflects back from the disk, the receiver should pick-up the light - in this case it doesn't. It lights up because you can burn. Try another drive - external (USB) or internal (replace the one inside the computer).
Nov 09, 2010 | Pioneer DVR-212D Burner
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
What type of disks does my TS L632D burn? +- ,CD, DVD Can't get CD's to burn?
go to my computer and look at the cd drive.if it says cd-rom you can't burn cds,dvd-rom will not burn dvds.only cd-rw,dvd-ram,dvd/cd-rw can burn cds.dvd-+,dvd-minus and dvd ram can burn dvds
Aug 04, 2009 | Computers & Internet
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Nov 17, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Toshiba Satellite A135-S4527 Notebook Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
