Question about ION Audio TAPE2PC Single Cassette Deck
Audio tape cassettes,old pre-recorded and home recorded play too slowly and drag. All brands. Tape deck plays new tapes fine.
  • 121 Answers
A good cleaning to the rollers and tape head with a qtip and a small amount of rubbing alcohol should do the trick
Posted on Feb 26, 2009
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
You can press play and pause, but then you can't press down rec. help.
Is the erasure prevention tab missing from a commercial or previously recorded cassette? It would leave a little (about 1/8" square) hole in the spine edge of the cassette shell. That tab is there to prevent accidental erasure by allowing a small sensor lever to drop in and mechanically disable the recording mechanism. Compare a commercial cassette with a brand new blank one. You can place a piece of adhesive tape on the casette to allow recording, but take care to NOT cover more than the first 1/8" of the opening if it is larger as the recorder also senses tape type by the length of the hole molded into the cassette.
Word to the wise - don't scrimp on the tape if the recording matters to you. Spend a bit extra for better tapes. Store the tapes 'played', avoid fast forwarding and rewinding unless you'll be playing them through to wrap the tape uniformly before storing it INSIDE its tape box. Read the other warnings that come with the media. No heat, moisture, dust, blah-blah.
Jul 08, 2009 | ION Audio TAPE2PC Single Cassette Deck
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
I think the actual tape cassette is the problem not the player. olde tapes play very slowly, dragging, distorted sound. New tapes are fine. What can I do to re-vitalise the old draggy cassettes?
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | Audio Players & Recorders
GoVideo Dual Deck VCR Model#GV6015with one touch copy
It seems to be fixed. I ran a new tape through the machne as suggested. To be sure, I also used a VHS head cleaning cassette.Works fine, now. Thanks
Feb 22, 2008 | Televison & Video
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
ION Audio TAPE2PC Single Cassette Deck Logo
239 people viewed this question
Top ION Audio Audio Players & Recorders Experts
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
