I think the actual tape cassette is the problem not the player. olde tapes play very slowly, dragging, distorted sound. New tapes are fine. What can I do to re-vitalise the old draggy cassettes?
  • 121 Answers
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Posted on Feb 26, 2009
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
I have a 91 Honda Accord with the original FM/AM/Cassette stereo. I use a cassette car audio kit for my cd/mp3 player and the cassette player has flipping sides while the tape for my audio player is in...
probably the belt for the pullys inside are worn, if you can get replacement ones they are easy to fit, just open the case and slip the old one off and new one on.(may have to remove an internal cover also)
Oct 10, 2009 | 2006 Hyundai Tucson
Loud buzzing when I insert a tape in my car's stereo
Hiya, first try a normal cassette, see if that plays OK. If so the deck is probably fine, if not then the deck is faulty (probably not serious though and just a loose wire on the head).
If the connection between the tape and MP3 is a cable, the fault is quite likely there (if bluetooth then not). I strongly suspect the cable from the previous issues also.
Best of luck
Jul 15, 2009 | RCA RS2640 CD Shelf System
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
Cassette players jammed
actually you can not lubicate the cassette players. it has to do with a belt inside. your players may need to be demagnitized. i would go to radio shack or electronic store and try a cassette cleaner/demagnitizer and see if that solves the problem. i would even try different batteries or a ac power adapter if you have the plug. some batteries make units run slow. i would even get a can of dust cleaner that you find in the electronics section. you spray it in and it cleans the inside of the dust that may be inside.
Mar 22, 2009 | Sony Audio Players & Recorders
Audio tape cassettes,old pre-recorded and home recorded play too slowly and drag. All brands. Tape deck plays new tapes fine.
A good cleaning to the rollers and tape head with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | ION Audio TAPE2PC Single Cassette Deck
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
113 people viewed this question
 Grubhead
Grubhead
