Question about Nokia 6234 Cellular Phone
Nokia 6234 headset not connected but phone thinks it is
The headset symbol is showing on my phone which means i cannot hear anything unless i put the phone on speaker or plug in the headset. when i take the headset out it still thinks it is in.
  • daman_sharma Mar 15, 2010
    i cannot hear anything how i could repair my phone
nanbuenbrazo
  • 553 Answers
SOURCE: Nokia 6234 headset not connected but phone thinks
have you try to turn off your unit and try to open it again?
If still there you will need to normal reset your phone, try to save all your files, back it up , remove the memory card and the sim card and open your unit again
press *#7370# then if it required code then type this code 1234 or 12345 (unless you change the security code)
then try to open it again
Posted on Nov 13, 2009
Headset symbol always on Nokia 6223 when I have no headphones. I can not hear anything now unless i go on loudspeaker. help
connect the phone with computer with the help of usb cable and update the phone software with the help of nokia pc suit then restart the phone.... thats it......
Jun 13, 2014 | Nokia 6233 Cellular Phone
The headset symbol is showing on my screen on my N97 and I dont have a headset connected at all, when people ring me they can hear me but I cant hear them because apparently my phone thinks there is a...
The headset jack is jammed.
Try blowing some compressed air in there and also insert a headset plug and wiggle it about to see if it knocks the stuck bit loose.
Mar 05, 2011 | Nokia N73 Cellular Phone
Nokia 6234 headset not connected but phone thinks it is the headset symbol is showing on my phone which means i cannot hear anything unless i put the phone on speaker or plug in the headset. when i take...
Nov 13, 2009 | Nokia 6234 Cellular Phone
Nokia 6234 headset symbol wont switch off - have tried switching phone off and removing battery; tried cleaning connection plug but still wont switch off - having to use loudspeaker to use phone... please...
Do a master reset from settings where the factory code is 12345. If this ain the problem take it to a service and they will do that for free because this is a common 6234 problem and one of the many problems that determinated the Nokia company to stop producing this type of phone!
Oct 22, 2009 | Nokia 6234 Cellular Phone
What does the headset symbol on a nokia 6070 screen mean? I can make calls but the line goes dead after the connection is made
it only shows when you connect a head set to your phone check wether you have connected the head set properly it mainly cause due to losse connection in the head set port
Oct 19, 2009 | Nokia 6070 Cellular Phone
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
Phone shows its on headphone but its not
This mostly happens from water damage to the connection ports. Use some 91% alcohol and wipe the connections with a toothbrush. Hopefully it will disconnect from headset mode
Mar 11, 2009 | Nokia 6288 Cellular Phone
Nokia 6288 fault
koo73 - you need to do a reflash the software on the phone.
lou75 - you need to have the earpiece replaced and speaker
May 20, 2008 | Nokia 6288 Cellular Phone
Only works on loadspeaker
The problem is with the socket where you insert the handsfree. Sometimes the socket connection is not released internally after removing the jack. Please insert the handsfree to its jack socket and remove it. Try again.
If not possible, a repair technician has to do it.
Oct 29, 2007 | Nokia 6288 Cellular Phone
Nokia 6234 Cellular Phone Logo
199 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
